Sponsored by: Innova
93 Explorer no sound
Old Oct 14, 2004 | 09:50 PM
betofoster's Avatar
betofoster
Disconnect battery
Try disconnecting the battery and the connecting it again. I had the same issue and this seemed to work.
Old Oct 18, 2004 | 07:29 PM
bchitwood73's Avatar
bchitwood73
If your OEM tape deck had DNR or something like that printed on the face of the tape cover then you have 2 amps in the rear kickpannel, and also a 6.5'' sub (if you can call it that). The whole system in your rig is made my JBL and to be honest, the door speakers are pretty decent. If you want to drop an aftermarket deck into this rig then you have two options. 1: Pull the OEM amps out and rewire everything from the dash to the amps. 2: get a high level input converter and wire it up to the OEM wires. I went with option #1 in my 93 EB Explorer and after about 5 strait hours of guesswork, I have the complete list of what color wires do what in the rear of the Explorer. Personally, I would ditch the OEM amps if you want good sound, they are a joke.
