My new entertainment system
Well, it didn't take me long to break my "I'm leaving it stock" promise. Have a look in my gallery by clicking the link, or find it under my avitar. As you will see, all I need to do is to figure out what to do with the cigarette lighter hole.
https://www.ford-trucks.com/user_gal...&albumid=11621
Does anyone know anything about this system? Looks pretty slick and easy.
http://www.autotoyaz.com/peoem7hemo2f2.html
Originally Posted by blitzen25bm
that looks great, i was wondering how mine would look like that then i relized my dash is different. what are the specs/brands on your equipment.
Where did you pick up the raw monitors and how much were they? I've been looking for some of those, I've had something like yours in mind plus going to mount one in each headrest, and maybe even a fourth in the panel above the glove compartment. Anyway, I havent been able to find the raw monitors so I would really appreciate it if you could let me know where to look.
Thanks!
shane
Thanks!
shane
Well, I got the screen from a dealer-friend of mine, but try Myronanddavis.com to see the actual makers, and maybe you can find a dealer from there. Mind you, the screen came in a casing, which I carefully removed; it didn't come raw. It wasn't all too bad to take the guts out of the shell, but it voids the warrenty immediately. E-bay also has a few raw screens, but make SURE it is an Active Matrix/TFT screen. Cheaper ones are not TFT and are noticably less clear, and low quality. Far less pixles. Again, most will be in a shell, so just be carefull when removing everything. I'll go take some pictures of the internals in a few minutes and will post them in my gallery, so check in a few minutes.
Thanks for the updated pics, that helped alot to understand what you had done...that's a lot of modification to the electronics, props to your talent! What all did you have to do to get the CD player to fit into the cup holder area? Was there any cutting or were you able to make a bracket to mount it? Thanks for the insight so far!
shane
shane
Actually, the cup holder assembly all snaps together/apart (after you unscrew it from the truck that is. And, the CD player fits almost perfectly in the main cupholder bracket piece (after anything/everything that can come off of it is taken off) Heck, there are even two holes in the plastic that ine-up with the screw holes in th CD player. It's almost as though it was made to fit it! The ONLY cutting I have done to any Ford part is where the DVD tray opens through the dash, where the little cigarett panel is (behind it actually)...but nothing visable, that's the best part. And, it can all be put back to stock if need-be! Thanks for the comments.
Originally Posted by lardman
Looks nice. Drive safe.
