Impact wrench
Old Sep 18, 2004 | 06:35 AM
srercrcr's Avatar
srercrcr
Impact wrench
Some dodo tightened the lug nuts so tight, I can't budge them with a breaker bar.....or even a three foot pipe on the bar!
Thought maybe this might be the time to buy an electric impact wrench.
Don't want to invest in a hardly-ever used-compressor and hose.
Do electric ones work good?
Old Sep 18, 2004 | 06:50 AM
TxBrokenarrow's Avatar
TxBrokenarrow
I've Seen On Tv The Nascar Pit Guys Use Them In Shop I Think They Said They Could Change 50 Wheels With Them Before Recharging...sounds Like Might Be Exspensive Though...might Be A Good Tool To Have When Broke Down Somewhere Or I'n Your Shop...let Me Know If You Try It And How Much...
Old Sep 18, 2004 | 08:39 AM
fellro86's Avatar
fellro86
Take a dead blow hammer to the end breaker bar, it works the same as a impact wrench, only slower, I have gotten bolts loose this way that my impact couldn't even do.
Old Sep 18, 2004 | 04:47 PM
85F_150driver's Avatar
85F_150driver
ive used one befor it worked pretty good, but they cost about the same as a compresser, but if you were only going to use it rarely i would get one. Check the torque rateing. you will need one rated 250 ft lbs or better probably to get them loose. Might want to try a longer pipe with a good breaker bar and socket so if you break them you can get them replaced for free. Good Luck with it.
p.s. i had that same problem once took a 6 ft pipe on a 4way lug wrench along with another person to hold the wrench strait.
Old Sep 18, 2004 | 05:17 PM
djd19852004's Avatar
djd19852004
Talking
something else you can try is a pipe wrench if space will allow you to do so and you might also find a bigger guy to hang from the pipe you are using as a breacker bar
Old Sep 18, 2004 | 06:35 PM
Katmandu's Avatar
Katmandu
Thumbs up
They don't cost that much.
I bought mine from Harbor Freight for under $50!! I love it!! Use it ALL the time!
http://www.harborfreight.com/cpi/cta...emnumber=45252
