Aerostar Ford Aerostar
Help! Weird Electrical Problem
Old Jun 12, 2000 | 04:52 AM
TallPaul's Avatar
TallPaul
My wife came out of WalMart the other day and started her 92 3.0 Aerostar. The air conditioning (at least the fan), power windows, radio, and turn signals would not operate, but the check oil, door ajar, battery, and rear ABS lights all stayed on. She slowly drove home on the service drive for three miles and then when she hit a bump in the road everything came on and the dash lights went out. It then was fine all the way to the grocery store and back. Apparently there is a loose connection or something, but given the miles of wire and the multitude of electronic devices in a car, I don't know where to start looking and guess I can't look anyway unless it is screwed up again and stays that way. Anybody ever have this problem and, if so, is there some particular device prone to this problem that I could just change and hope it never happens again?
Old Jun 13, 2000 | 07:14 PM
nitro94's Avatar
nitro94
If it ever happens again I would try giggling the Ign. switch just a little bit. If problem goes away replace Ign. switch.
Old Jun 14, 2000 | 06:20 AM
TallPaul's Avatar
TallPaul
Thanks, That is a very logical response. All the above conditions occur when the ignition switch is turned to the starting position. If the switch were off a bit it could allow the car to run but still in that mode. (Hopefully the starter was not engaged all that time!!) Also, I had the ignition switch replaced once because it was very difficult to get the key out.
Old Jun 22, 2000 | 09:04 AM
TallPaul's Avatar
TallPaul
You were right! It did it again, she wiggled the key, and it was fine. Thanks, you saved us a lot of trouble.
Old Jun 22, 2000 | 07:04 PM
nitro94's Avatar
nitro94
Every once and a while I get one right. Thanks for the feed back.
Old Jun 23, 2000 | 07:57 AM
michelli67's Avatar
michelli67
