problem removing spark plug
Old Sep 17, 2004 | 09:17 PM
ewellman's Avatar
ewellman
I have a 92 F150 300 i6. I have one plug that I can turn out 2 or 3 turns and then it won't turn any more. I am worried that if I try too hard it will break off in the plug hole. Has anyone else had this problem? If so, how do I go about removing this plug?
Thanks in advance.
Old Sep 18, 2004 | 12:57 AM
Muffinman's Avatar
Muffinman
Put some Marvel Oil on the plug base and let it sit for about 30 mins.
Old Sep 18, 2004 | 09:00 AM
65CJ5's Avatar
65CJ5
Agree. Or you may even need to put some Marvel in several times over the course of a week. Patience is your friend on this. I had to soak the steering wheel nut for TWO weeks before I could get it off. That baby was rusted on there. But it came off nice and easy without breaking anything. That's what you're after.
Stan
Old Sep 18, 2004 | 09:34 AM
ewellman's Avatar
ewellman
Thanks guys. I will try the Mystery Oil. I had some guys tell me to use WD40 and keep working it back and forth until it comes loose. Haven't tried that yet.
Old Sep 18, 2004 | 09:40 AM
BillC's Avatar
BillC
That's correct, just do it slowly and have patience. That procedure worked for me. Good luck!
Old Sep 18, 2004 | 09:20 PM
hdgapeach's Avatar
hdgapeach
And when you get it out, if there is burred debris on the plug, get a clean out tap and chase the plug hole threads. Put grease on the tap before turning it into the head so any debris will stick to the tap instead of falling into the hole.
Old Sep 19, 2004 | 03:19 PM
Franklin2's Avatar
Franklin2
The problem is more than likely carbon build-up on the end of the plug clogging the threads. Working it back and forth with solvent/oil should eventually break the carbon up.
Old Sep 19, 2004 | 10:11 PM
ewellman's Avatar
ewellman
Thanks for the input guys. I got that plug out. It must have been carbon build up. When I loosened it today it started out find then started to turn hard but came right out.
aba4430
Sep 3, 2012 08:59 PM
erica
Oct 1, 2009 03:54 PM
thbowen
Apr 24, 2009 06:02 PM
1978Supercab
Feb 13, 2006 03:36 PM
MDraper
1978 - 1996 Big Bronco
15
Dec 29, 2002 03:54 PM
