Sponsored by: Auxito
More pulling power tips....need some
Old Sep 17, 2004 | 08:44 PM
daytomann's Avatar
daytomann
I have an 01 F-150 SuperCrew 4X4 5.4L...automatic...3.55 gears with 55,000 miles on it.
It is all stock and has been well maintained.
I just bought a boat. Total pulling weight is around 4500-5000lbs..well within the max towing capacity.
The truck tows fine (although I definately can feel the boat back there) and I get about 11-12mpg on the highway.
I just want to know if there is any bolt on tips or any tips in general on how to help improve the towing performance with gains in HP and torque. I am just wanting to maximize the performance of the truck as much as possible and to try to reduce wear and tear.
Please no.."yeah, heres a tip...get an F-250" remarks...
Thanks in advance.
Old Sep 17, 2004 | 09:36 PM
CPerry's Avatar
CPerry
I recently bought a new boat and wanted more pulling power out of my 1999 F150 4X4 so I installed a Microtuner which has a performance towing tune that adds more torque and HP. I also added a cold air intake and flowmaster exhaust. After putting on larger tires I had 4.10 gears installed and now it tows my boat with relative ease.
Old Sep 17, 2004 | 09:38 PM
superrangerman2002's Avatar
superrangerman2002
A diablo predator, or a MAC intake, or both would be fine additions to your rig.
You can buy both off of this site.
Welcome to FTE!
Old Sep 17, 2004 | 09:47 PM
southernfordman's Avatar
southernfordman
granatelli max airflow sensor
air intake
exhuast
reprogramer
lower rear end gears
throttle body spacer(mostly for torque and milage gains)
headers
new bigger throttle body
royal purple oil, tranny oil, rear end oil and i think radiator fluid
There is alot of things out now to add power.
Old Sep 23, 2004 | 07:24 PM
daytomann's Avatar
daytomann
Thanks for the welcome and thanks for the tips!
Sounds like pretty straight forward stuff. I've already done alot of these type mods to my wife's 03 Mustang GT and they all seem to have worked good.
Sounds the the truck stuff is pretty closely related.
But anymore would be appreciated.
I may have some more questions.
Since I've got 3:55 gears, sounds like I need some new gears and a programmer/tuner first to set some new F.I. tunes and to reset for the new gears....(and a cold air intake, cuase they are relatively inexpensive).
Then some flows....probably a catback system would be best.
If I decide to keep the truck for a couple of more years I will get the new throttle body and maybe some headers.
Do they make underdrive pulleys fro our trucks? and do they add anymore power or responsiveness?
Old Apr 26, 2005 | 03:18 PM
daytomann's Avatar
daytomann
Bumping this up...anymore suggestions?
Old Apr 26, 2005 | 06:48 PM
peppermrj's Avatar
peppermrj
The gears will help (run 3.73's 98 5.4) but are there all the time (gas mileage). Larger wheels/ tires hurt as far as towing goes.
Since we are spending your money, Supercharger?
Also and more importantly "More stopping power tips"
Upgrade to performance pads and rotors next brake change.
No experience with underdrive pulleys. How bout some pics of the new rig (boat attached).
Happy Motoring.
Old Apr 26, 2005 | 09:06 PM
daytomann's Avatar
daytomann
Well the supercharger is out for now LOL!
I got the boat at the very end of last summer. I only put 20 hrs on it last year so I only towed it on the highway a few times.
One thing I decided since then is that I am probably not going to change gearing.
Right after I got my boat, my buddy got a new 04 F-150 4x4 Super Crew to tow HIS boat.
His boat is exactly like mine in style, size and weight.
His truck has 3:73 gears and the more powerfull new motor. Its supposed to tow easier than my truck and was supposed to get better gas milage when towing.
Both times we towed our boats I got BETTER milage than him, by .5 to 1 mpg. I think it was my gearing that did the trick. Once we are up to speed, I'm running at consistantly lower RPMs.
I think I'm gonna just put on some bolt ons and try to increase power a little. I might just leave the gearing alone cause it does pretty good with the 3:55. Not as good on the bottom end but it does OK and pays off for the better milage.
So far my "for sure" bolt ons (which I will install next month) are the K&N GEN II CAI, and Flowmasters. I'm still trying to decide on what else to do.
Old Apr 26, 2005 | 09:09 PM
daytomann's Avatar
daytomann
I hear ya on the brakes, that'll be very soon.
Old Apr 26, 2005 | 09:11 PM
daytomann's Avatar
daytomann
how do you post a pic on here?
Old Apr 26, 2005 | 09:18 PM
peppermrj's Avatar
peppermrj
Post
That belongs in the how to post a pic forum. Wish i could figure it out!
Old Apr 29, 2005 | 09:42 PM
Camille Marquis's Avatar
Camille Marquis
I have the diablo preditor and under drive pulleys recommend them both and have towed 550lbs with it no over heat but be sure to run better than 91in the tank
Old Apr 30, 2005 | 09:11 AM
daytomann's Avatar
daytomann
550lbs? do you mean 5500lbs?
Old Apr 30, 2005 | 02:51 PM
Camille Marquis
Yes 5500 cant you tell i am a bad speller
Old Jul 27, 2005 | 11:54 AM
berto's Avatar
berto
Airforce One is a good intake as well.
I have been wondering about underdrive pulleys. Are they worth the money for the performance and which brand is the best? Can you feel the difference?
What about headers? What brand gives you the most power?
Robert
