Aerostar Ford Aerostar
Aerostar Trans Fluid ?
Old Apr 12, 2000 | 08:51 PM
Ed's Avatar
Ed
I have a '87 Aerostar XLT (3.0L v-6) and was wondering about changing the trans fluid and filter and using a brand name synthetic ATF. The transmission is working fine, but I know the early ones are prone to problems, which I am hoping to avoid with regular maintenance. Has anyone used a synthetic ATF in their Aerostar? If so, what brand, and comments pro or con you may have. Thank You! Ed...
Old Apr 13, 2000 | 09:06 AM
TallPaul's Avatar
TallPaul
I try to change the ATF every 25000 miles or so. My wife's Aero is a 92. My mechanic said that in 92 Ford added a tranny cooler because they had had problems with the tranny. You may want to add a cooler to yours. As for using synthetic, it is supposed to handle heat better and give improved cooling. I don't know if it is recommended for your truck though.
Old Apr 13, 2000 | 08:45 PM
Mikeman's Avatar
Mikeman
I switched to Mobil 1 in my 95 Aerostar AWD and used it everywhere Mercon was specified (front axle, transfer case, tranny). No problems with the change to synthetics, shifting seemes a little crisper afterward. My thought is this: Because I do the work myself, I can use the better stuff and still do it for less than any automotive repair shop. I don't plan on extending the intervals for changing the fluid with synthetics but if I were using non-synthetics I would shorten the fluid changing intervals.
Old Jul 11, 2000 | 10:15 AM
fiftynine's Avatar
fiftynine
Ive got an 87 Aerostar that ive owned since 1990. it has almost 200,000 miles on it and hardly any problems.I installed a drain plug in the tranny pan and change it every time i change my oil.it keeps the the fluid clean and the tranny running strong
Old Jul 12, 2000 | 09:53 PM
MarkP's Avatar
MarkP
I change my 88 Aerostars and also my other cars auto trans fluid and filter at 30K intervals doing it myself. The drain plug is a good idea I considered but never got around to doing. Since the truck only just turned 60,000 miles,
maybe next time in say six or seven years.
I've never used synthetic oils since I only change motor oil and filters every 6 mo. or 4000 miles whichever comes first and the engine is just fine.
Old Jul 15, 2000 | 05:51 PM
Phillip Guidry's Avatar
Phillip Guidry
kawika
49
Jun 23, 2021 11:47 PM
Troyus
Mar 7, 2016 06:42 AM
Enomra
Jul 10, 2012 01:08 PM
geearturi
Aerostar
Jan 21, 2012 04:53 PM
old-rodder
15
Oct 27, 2011 08:18 PM
