Aerostar Ford Aerostar
93 Aerostar brake system
Old Aug 22, 2000 | 11:33 AM
Avanti's Avatar
Avanti
I flushed the brake system on my 92 F-150 and 89 Bronco II. Had my son pump the brakes while I bled each wheel. I want to keep the system clean and especially keep the sludge out of the antilock unit. Can I do the same with the system on my 93 all wheel drive Aerostar? I have the factory shop book and it is not too clear on this.
Old Aug 23, 2000 | 02:57 PM
Mikeman's Avatar
Mikeman
I just got done partially flushing the brake system on my '95 4WD Aerostar two weeks ago. The only problem I had was that the bleeder screws were corroded so badly that I broke one off on the left rear wheel cylinder. So, when I checked the front caliper bleed screws and found them just as badly corroded, I called it quits rather than risk busting off the bleed screw and having to replace the caliper. I used one of those hand vacuum pumps to flush the system so that I could do it without having someone pump the brakes.
Old Aug 24, 2000 | 10:13 PM
bob_a's Avatar
bob_a
Brian Skinner
Aerostar
Mar 20, 2015 10:27 PM
tmajikman
Aerostar
Jun 30, 2014 10:39 AM
Avanti
Aerostar
May 2, 2002 10:02 PM
chrisa
Jul 8, 2001 05:47 PM
old fool
Aerostar
Mar 23, 2001 08:56 AM
