Bright side, Calculus, and Vehicles
Old Sep 17, 2004 | 03:21 AM
TheImpaler's Avatar
TheImpaler
Here I am, 1:30am trying to focus on some Calc. homework that I have no interest in doing. I decide it's time to check the forums for a break, and what do I see? None other than Mr. T himself, telling me I need to post more often. If I don't? Pain.
Sweet.
Anyway, I finally got a chance to look at my truck on Wednesday, and I camme to find my whole rocker assembly had loosened up on me. Strange.
Tightened that that down * to torque specs, again* and readjusted the valves. She is running purdy again. Certainly not the fastest thing in the world, but it beats the Toyota Camry.
...And it sounds wicked.
-Patrick
Old Sep 17, 2004 | 06:42 PM
spurredon's Avatar
spurredon
Are you using the proper tightening sequence?
Old Sep 17, 2004 | 08:49 PM
Scouder's Avatar
Scouder
I didn't know there was a sequence on the rocker shafts, just that they needed to be done evenly.
Is there really a sequence?
-Scouder
Old Sep 17, 2004 | 09:16 PM
spurredon's Avatar
spurredon
If you have the rocker shaft completely off, first rotate the engine to TDC on #1 and then turn the crank an etra 45 degrees. Then you can start each bolt finger tight. Next you want to go either #4 or #5, depending on which side you are working on, and tighten each bolt 2 turns in sequence untill the bottom of the supports come down on the heads. Then you can torque each one in the same order
Old Sep 20, 2004 | 12:03 PM
debestuss's Avatar
debestuss
I was eating my lunch and dude walked by and gave me a hot pepper. Understatement. Anyway, I've always just tightened my rocker arms systematically but never any set sequence. No problems so far (knock on wood)
