Motor Mounts?
Old Sep 16, 2004 | 11:15 PM
Argo's Avatar
Argo
Motor Mounts?
I know I've seen it covered before, but can't seem to find any information in my search for heavy duty motor mounts for my 300. I am tired of having to do them every year or two, and was hoping that some solid or polyurethane ones had been concocted by now to solve this problem. If not, I'd like to hear some suggestions from y'all on how you guys handle it.
Old Sep 17, 2004 | 07:39 PM
50_Buck_Work_Truck's Avatar
50_Buck_Work_Truck
3 or 4 strategically placed 3/8" or 7/16" carriage bolts and a little grinding? Big mama Grade 8 bolt where it won't hit anything? Mine had a big rivet clamping the rubber sandwich together, didn't last. After application of the ol' Ford Locking Motor Mount Trick, this is no longer an issue! Now all I need is a polyurethane tranny mount when the one I just replaced goes south...
Old Sep 17, 2004 | 08:32 PM
benwantland's Avatar
benwantland
I ran a chain from the top motor mount bolt to a hole drilled in the mount tower... solved my problems...
