88 ranger 2.9
Old Sep 16, 2004 | 08:06 PM
DIESEL DAD's Avatar
DIESEL DAD
Question 88 ranger 2.9
Have any of you ever replaced a 2.9 with a 2.8? I have a good 2.8 in an 84 Bronco II that I would like to put into an 88 pickup. Will it work?
Old Sep 16, 2004 | 08:48 PM
Ken00's Avatar
Ken00
Welcome to FTE!!!
The 2.8 & 2.9 are the same basic block so it should fit fine, you'll have to swap everything engine/tranny related over I bet.
Old Sep 16, 2004 | 08:49 PM
Help I M Stuck's Avatar
Help I M Stuck
everything from that 2.8 will have to go with it..trans is the same and will bolt right up. wiring/computer/exhaust headers...
Old Sep 19, 2004 | 08:24 PM
Loan Ranger's Avatar
Loan Ranger
The 1984 2.8 engine had a Motorcraft 2150A carburetor. The 1988 2.9 is, of course, fuel injected. The in-tank electric fuel pump has way too much line pressure than the needle and seat in the carb was ever meant to handle. The pressure must be reduced tremendously.
The engine control computer from the 2.9 shares nothing with the ignition on the 2.8 engine. Both engines used the TFI system. They will interchange, of course. But the 2.9's computer is not even necessary and won't wire up at any rate.
While the ignitions interchange, the wiring harness for the 2.9 will have about a zillion connectors no longer needed. However, the 2.9 harness does have connections for power distribution (Ford base number 14409) to the rest of the truck. The electronics involved in the change will be a confusing issue.
Fitment is, of course, no big issue. Both are the same engine families and both share common dimensions, fastener sizes, mounts, bellhousing pattern and the like. (It would be quite similar to pulling a 302 out of a 1966 Ford and putting a 289 in its place.)
The most complicated part will be ensuring that all the electrical components retained have a power source. Even the fuse boxes from 84 and 89 are totally different. Once that is sorted out correctly, the rest should be pretty easy.
The fuel delivery system will need a great deal of "tweaking" in order to get it right.
Old Sep 24, 2004 | 06:12 AM
DIESEL DAD's Avatar
DIESEL DAD
Can the 2.8 accept all the fuel and electronics from the 2.9?
tom3tone
May 25, 2007 02:00 AM
lwcassady
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 25, 2005 09:44 AM
oldhalftons
Nov 1, 2004 12:03 AM
gt390dk
Apr 7, 2004 04:44 AM
jakask
Nov 29, 2003 11:03 PM
