another minor problem
Old Sep 16, 2004 | 04:06 PM
wipper's Avatar
wipper
i need to change the rear windshield wiper moter. so after taking off the nut holding the wiper arm on it will not budge
so i need to know if the arm has splines on it or is it just a tight fit ( it is a NY truck so salt maybe the problem) i just dont want to break it taking it apart
Old Sep 17, 2004 | 05:03 AM
Monsta's Avatar
Monsta
Sit. Stay.
It has splines but also has a catch underneath the arm. It is usually located right under where the arm starts. You'll have to lift the arm up.
Slide the catch over with a flat blade screwdriver and the arm should pull right off.
Old Sep 17, 2004 | 07:41 AM
daimon1054's Avatar
daimon1054
2 words
BIG HAMER Just beat on things for a while it stuff will just seam to fall right off Just hope it's the stuff you wanted to have fall off
Old Sep 17, 2004 | 01:02 PM
wipper's Avatar
wipper
i think you are thinking of the front wiper there seems to be no catch , or i haven't noticed it
Old Sep 17, 2004 | 01:50 PM
daimon1054's Avatar
daimon1054
USE THE HAMMER
I'll go look and see if I can see anything. No promises!
Old Sep 17, 2004 | 01:56 PM
daimon1054's Avatar
daimon1054
It is a tappered fit, there are splines and a lot of dirt could get in there and stick it on. I loosened the nut but left it on for leverage, then put my thumb on it and wiggled and pulled and it popped off. There are not catched and nothing other than the nut.
Old Sep 17, 2004 | 01:59 PM
Monsta's Avatar
Monsta
Sit. Stay.
Whoops...I must have been thinking of a different vehicle...
Old Sep 17, 2004 | 02:03 PM
daimon1054's Avatar
daimon1054
Some moderator you are making a brutha screw up his truck you should be hung at sunset! I would say sun rise but I ain't gettin' up that early
