'05 6.0 Changes
Old 09-16-2004, 09:46 AM
kw5413's Avatar
kw5413
kw5413 is offline
'05 6.0 Changes
Probably need to copy this before it goes away.
Super info with pic's.
Looks like the biggest change is...they deleted the rest of the truck!
http://www.fordtechservice.dealercon.../2005_6.0L.pdf
Old 09-16-2004, 09:55 AM
IB Tim's Avatar
IB Tim
IB Tim is offline
Site Administrator
cool pictures
Old 09-16-2004, 10:15 AM
kw5413's Avatar
kw5413
kw5413 is offline
Old 09-16-2004, 10:34 AM
moosekingranch's Avatar
moosekingranch
moosekingranch is offline
WOW! KW, that is some really great stuff. I got so tired of the dealer telling me he did not know what changed on the 05 6.0L. Thanks!!!
Old 09-16-2004, 10:58 AM
montanacw's Avatar
montanacw
montanacw is offline
So do I have some of these changes in my truck, I have a 04 F350, with a build date of 02/04 and engine build date of 02/04? The chages say they started in Jan 04.
Old 09-16-2004, 11:11 AM
kw5413's Avatar
kw5413
kw5413 is offline
By my read some items, like the VGT Control Valve, can be retro-fit to the '03 / '04 6.0s.
Many items, it seems, cannot. Compatability is carefully noted at the end of each description for most applications.
Old 09-16-2004, 11:16 AM
moosekingranch
05 EGR system redesign
Looking at the chages made to the EGR system, I posted in Stickey regarding unplugging the EGR. This opens up a new discussion on whether or not 05 owners have risk in unplugging the EGR. Here is a link to the post:https://www.ford-trucks.com/forums/s...&page=15&pp=25
Old 09-16-2004, 11:41 AM
Frobozz's Avatar
Frobozz
Frobozz is offline
It says June 29, 04 as far as I can see (page 3), with serial number 6344943.
So I would say "NO" - only actual MY 2005 trucks have these changes.
Duncan
Old 09-16-2004, 11:57 AM
montanacw's Avatar
montanacw
Duncan
OK, But, My engine and truck were built after Jan 04, so if thats correct, then I must have these changes. I need to check my serial number for my engine. Is my engine serial number located on the same sticker as the
build date?
Old 09-16-2004, 12:33 PM
Frobozz's Avatar
Frobozz
Frobozz is offline
build date?
June 29, '04 comes quite a bit later than Jan 04 so your truck wouldn't have these changes. Or am I the one that's confused? (Talking about MY 2005 trucks being built in 2004 is bound to get one of us confused!)
The serial number should be on the label on the FICM cover, yes.
Duncan
Old 09-16-2004, 09:51 PM
kw5413's Avatar
kw5413
kw5413 is offline
Looks like they have really settled in to fine tuning the 6.0 now. Doesn't seem to be as many changes as the '03 - '04. And there shouldn't be.
Old 09-17-2004, 08:02 AM
KurtNJr's Avatar
KurtNJr
KurtNJr is offline
kw5413 - You are correct - the 05 is a smooth outfit. I can't find anything to complain about (except the power seems to be less than the 03 strategy and we know how to fix that).
Old 09-17-2004, 09:43 AM
montanacw's Avatar
montanacw
OK, I feel like an idiot!
I just realized that the changes are JUNE not JAN 04, Sorry for the confusion!!
I should learn how to read
Old 09-17-2004, 12:44 PM
KurtNJr's Avatar
KurtNJr
KurtNJr is offline
This may be worthy of its own thread! I just noticed that draining the HFCM will no longer require the little hex wrench and entail diesel fuel running down your arm to your armpit. The new one has a little lever you open and spout to direct the fuel into a container. Can't wait to rub that one in to my friend!
Old 09-17-2004, 01:39 PM
Frobozz's Avatar
Frobozz
Frobozz is offline
WOOHOO!!! Been waiting for that one! Does it look retrofittable to the earlier ones, like maybe a valve that screws in where the plug used to go? Or a new cover to the little manifold, that will bolt on top of the old manifolds in place of the cover with the plug? Oh please oh please!
Duncan
Quick Reply: '05 6.0 Changes
