The number of pipes dont matter at all. Keeping exhaust velocity high and backpressure as low as possible is everything. Replacing a stock system with a better flowing setup that has properly sized pipes will build torque.
Going "too" big will not result in torque loss, it just moves further up in the powerband. Its still there, just in a different spot
you just went against what you just said, you don't want the lower backpressure as possible, otherwise, like said, you will not have much low end. number of pipes do matter. lets say you have a built stroker 460 with a turbo on it. you have a y pipe going into 1 pipe. turbo's need the backpressure to be gone, so you are going to get a 3 inch pipe. if it twin turbo, you could go with a 2 1/2 or 2 3/4 pipe if that is even made.
Backpressure creating low end tourque is an old wives tale. It's evil. What you actually want is high exhaust velocity with the lowest backpressure possible. Just like kens64 said, he knows what he is talking about.
Backpressure is restiction and that is not what you want.
ok listen to them but one you get 3 inch or whatever which you probably won't you are going to hate it because your low end will be gone. if you got cats then you should be ok though.
Yes you are correct, but not because of "low backpressure". A 3" on a low flowing motor like the 300 can allow the exhaust to "stack up" because of LOST VELOCITY. Lost velocity=lower speed. Higher exhaust speeds help pull the next pulse out w/ it (vacuum effect). Lower can make them bump into each other, slowing them even more (possibly creating turbulance). The cooling effect of the larger area also slows it down.
Your low end will not "be gone" because you go with 3" pipe. Only some torque is moved, not all of it..... Sometimes very little, it really depends on the engine. The torque moves up because, as the engine revs up, it finally makes use of the bigger pipe and velocity is good again.
Think about it, having a little more mid range torque can be a good thing if you're on the highway all the time. That extra mid range will help passing power, or pull a hill without having to shift down. Having the cats are not a help, they are a restriction, not a velocity producer, though I would leave them on or go with higher flowing units.
I would not go bigger than 2.5" on a mild 302. 2.25" is probably best for a stock 302.
what ive had in mind for my set up i wanna save up for is having the pipe exit infront of the back passenger side tire, but with something closer to a 45 degree bend, as opposed to the 90 degree bend i usually see out on the road.
should this be okay? it should keep the exhaust velocity up right? is there anyproblem with this (assuming texas emmission laws say its okay to have the pipe exit there)
It should be fine, and probably look beter than a straight cut pipe exiting there. Placement has nothing to do with velocity, its all pipe size and # of bends. I wouldnt worry about emissions either, as long as the cat(s) are not modified, you can have the exhaust exit anywhere you want.
yea, the main purpose for exiting infront of the rear tire is to prevent scraping, ive already scraped the bottom a lil on some extremly angled driveways and streets, when i get a new exhuast set up i dont wanna damage it too much too soon, hehe.
the angle is cuz i didnt think having such a sharp bend would be too good for the exhuast flow.
