True dual's or split???
Old Sep 15, 2004 | 09:41 PM
kenro's Avatar
kenro
Hey all!!!!I have a 03 SD 4x4 5.4 all stock.I want to know what would be better,true duel's or split from the muffler.I'd like to use a dynomax muffler or muffler's.I don't want it really loud.The sound clip for Dynomax is what I want,a deep sound.I think true dual's would sound better,but I don't know how hard it would be to have it done right.Any thought's would be great!!!
Old Sep 16, 2004 | 04:03 AM
kens64's Avatar
kens64
A split is cheaper, true duals usually sound better. A well designed true dual system will give you a little power too.
Old Sep 16, 2004 | 08:12 AM
Saurian's Avatar
Saurian
The removal of any restriction is best. The only problem is, the closer to the engine the restriction is, the more it hurts performance. So going with a new exhaust after the catalytic converters will help you a little bit, it will be mostly for sound. Without removing the catalytic converters, you will not be able to remove the greatest restriction, and also the closest restriction to the motor. If you want higher performance as well, you will need to replace the catalytic converters with their aftermarket "High Flow" counterparts...even though of all the manufacturers, there are only two actual producers, they're all just rebranded off eachother. Anyways, happy trucking.
cjben
Sep 17, 2015 04:02 PM
V10man
2004 - 2008 F150
16
Mar 3, 2015 10:27 AM
cdrmotorsports
Exhaust Systems
15
Feb 3, 2007 11:36 PM
luttersj
Exhaust Systems
22
May 28, 2004 09:48 AM
fordpower460
Exhaust Systems
Nov 27, 2001 03:27 PM
