Oil ? Gauge
Old Sep 15, 2004 | 11:50 AM
dehamma's Avatar
dehamma
Oil ? Gauge
I have an '89 F150 4X4 Lariat 4.9L M5OD and I have 4 gauges on the left of my cluster; (clockwise) altimeter, oil, coolant temp, and fuel. My question is what does the oil gauge measure? Does it measure pressure?
If it measures pressure, my reading is low. How do I diagnose this, if it is a problem? Oil pump failing?
Thanks
Old Sep 15, 2004 | 12:49 PM
andym's Avatar
andym
It measures whether or not your oil pressure is over 7 psi. Do a search on oil pressure gauge in this forum, it's been talked about before.
Old Sep 15, 2004 | 03:14 PM
EPNCSU2006's Avatar
EPNCSU2006
Ford didn't start the dummy guage thing until '90 I believe. At any rate, it's not very accurate, so it may as well be a switch anyway.
Old Sep 15, 2004 | 03:21 PM
andym's Avatar
andym
My 89's got a dummy gauge.
Old Sep 15, 2004 | 03:22 PM
EPNCSU2006's Avatar
EPNCSU2006
hmm, maybe it was '89 and I didn't remember correctly. Anyhow, my '87 isn't any more useful than a switch would be, so it doesn't matter too much.
Old Sep 15, 2004 | 07:28 PM
Steven@nd's Avatar
Steven@nd
My 88 is the idiot light with a needle too. If you ground it out completely it goes to the low side...
Old Sep 16, 2004 | 12:05 AM
Diggie's Avatar
Diggie
If you have the dummy with a needle, is there an accurate aftermarket electric that will just bolt in to the block and use the factory gauge?
Buddy with a '47 Chebbie was switching his from mechanical, he says just as accurate, less mess.
What do you think?
Old Sep 16, 2004 | 12:48 AM
aikigod's Avatar
aikigod
This link might interest you if you want to mess around with your gauges a bit...
Dummy Gauge
Old Sep 16, 2004 | 10:26 AM
jimandmandy's Avatar
jimandmandy
'86 was the last year of the "real" oil pressure sender, according to the parts catalog at the dealer.
Jim
Old Sep 16, 2004 | 10:55 AM
EPNCSU2006's Avatar
EPNCSU2006
I have a "real" sender on my '87, and I there was one on an '88 that I got a wiring harness from.
