Ford SHOULD BE SHOT!
Old Sep 15, 2004 | 07:56 AM
PSD6litre40's Avatar
PSD6litre40
Changed my first Airfilter last night after 20,422 Miles. And OMG what were they thinking! I thought I was gonna have to remove the engine just to change the filter, what a joke.............
Old Sep 15, 2004 | 08:01 AM
jdadamsjr's Avatar
jdadamsjr
Well, remember, it's engineers that DON'T have to change it....
working under design params that THEY don't set....
Some have found an easy way to do it...
takes less than 10 minutes once you know how...
Old Sep 15, 2004 | 08:10 AM
PSD6litre40
Please expand, I had to remove the intake from the turbo forward and THEN I broke one of the tabs of of my FILTER! So now I have another one on order and when it comes in I have to change it again..............
Old Sep 15, 2004 | 08:19 AM
jdadamsjr's Avatar
jdadamsjr
Let me find it... someone has posted it here...
it involves undoing the far back tube at the back of the intake and taking the whole unit out ...
and swapping the filter on the ground, then putting the whole unit back in...
much easier...
Old Sep 15, 2004 | 08:21 AM
Choctaw Bob's Avatar
Choctaw Bob
I solved the problem by replacing it with a K&N FIPK. It takes about an hour to remove, wash, dry and reoil the filter. It provides superor flow with equal filtration!
Old Sep 15, 2004 | 09:12 AM
hitecdan's Avatar
hitecdan
much easier...
Yes, it's much eaiser to remove the aft air filter housing and inlet tube, then remove the filter.
That's how I did it This way also give you a chance to inspect the turbo and look for any chafing wire bundles.
Or, you could try doing it Ford's way
Old Sep 15, 2004 | 10:44 AM
eharman's Avatar
eharman
That's the way I do it, I have down to under 7 minutes. The only time
I do though, is when I go to the dealer.
, EJ
Old Sep 15, 2004 | 11:54 AM
jdadamsjr's Avatar
jdadamsjr
So u disconnect between piece 4 and 5 on the diagram or behind piece 5 ?
http://dan.prxy.org/Truck/F-350_main...16-Feb-04.html
Old Sep 15, 2004 | 05:01 PM
Maxium4x4's Avatar
Maxium4x4
Kinda funny, when I brought my truck home I looked it over pretty good......saw the clips, figured straight up and out..... .....engineers....didn't take long to figure this out....nope.... ....ah...wellll..... .....it has to come out... ....not bending my pride to read the owners manual......ah....welll....ok....just take it out as unit... .....guess I was right.... Hope the engineer that came up with this bright idea is out of work.
Old Sep 16, 2004 | 08:27 AM
John Russell's Avatar
John Russell
Wow, this is a great thread-Thanks!
Boy oh Boy,
Am I glad to have found this thread! I have not changed my air filter yet, but it is due for a service this weekend! This would certainly be a frustrating first encounter without reading this post, and following the link jdadamsjr. posted!
Thanks,
John R
Old Sep 16, 2004 | 05:07 PM
bighoss550's Avatar
bighoss550
when u do get the filter out, chop the tabs off the bottom of the pipes so u dont have to worry about it again. once u do that it comes right up and out.
Old Sep 16, 2004 | 05:31 PM
Maxium4x4's Avatar
Maxium4x4
Hummm.....I will check that out....did it work an seal tight Hoss?
Old Sep 16, 2004 | 10:48 PM
npccpartsman's Avatar
npccpartsman
Kinda goes back to the engineers discussion in the V-10 vs 6.0 thread, huh???
Old Sep 17, 2004 | 07:58 AM
jdadamsjr's Avatar
jdadamsjr
Wow - good connection there npcc !!!
Old Sep 17, 2004 | 09:58 AM
R1ZOOM's Avatar
R1ZOOM
good post, thanks for the info
