Emblem removal???
Old Sep 15, 2004 | 01:37 AM
HawaiianStyle's Avatar
HawaiianStyle
Wink Emblem removal???
Hey Fellas need your assistance on the removal of the tailgate emblem. Does it need to totally come off to apply new decal? I noticed from past threads that it was removed by heat, (Blow Dryer or Heat Gun) is this the only way to remove this without causing damage to the paint? How did you remove the clear plastic shield around the emblem itself? I'm trying to do this with the least amount of impact to my Baby if you know what I mean. Any help you guyz can pass on would be greatly appreciated!
Much Mahalo! Derek
Old Sep 15, 2004 | 01:09 PM
GordoPanocho's Avatar
GordoPanocho
What are you planning on doing to/with the emblem? A few folks have removed the emblem, but it leaves three holes exposed. I guess what I'm asking is what is your desired end result? Are you looking to acetone them? Are you looking to put an overlay decal on them?
Old Sep 15, 2004 | 02:27 PM
HawaiianStyle
I'm doing what you guyz actually did to yours. BTW, I like how yours turned out, sharp emblem! I have the overlay but before I go pryin on it I wanted to make sure that this was the only way of removing the emblem. I read your earlier threads about the use of acetone and heat but wasn't sure if that was necessary. was it easy to remove the clear cover from the emblem itself?
Old Sep 15, 2004 | 06:13 PM
GordoPanocho
What you see in my gallery is an emblem overlay decal. It's just a high quality (fat/thick) sticker that's placed on top of the emblem. It's like putting a sticker in the back window ... but a it's more of a heavy duty sticker. No emblem removal is necessary!!! It just sticks on top of what's already in place. Did you buy custom decals from someone like Ivan of www.zDecal.com?
Old Sep 15, 2004 | 06:53 PM
Mezmo's Avatar
Mezmo
Mine was the same way as Gordo. You don't need to take the old one off at all. I bought from Ivan and it looks look great. Its not hard at all to apply.
Old Sep 15, 2004 | 07:42 PM
pornstar1969's Avatar
pornstar1969
are u guys talkin about the ford or the f-150 emblem on the tailgate cause i am curious if the f-150 has holes behind it
Old Sep 15, 2004 | 09:09 PM
HawaiianStyle
Gotcha! I was thinking from lookin at your previous post that you had removed it totally , pulled the clear plastic off, and put you Hookum' Horn on top of the Blue Oval and resecured the original clear piece. It looks as though you did it this way from the clear shine as if the clear plastic was now over your horns as if it was factory installed. Thanks for your help everyone.
****, if you do a forum search on emblems you will see Gordo's and a few others post and their detailed description to the Overlay Decals we are discussing. I think they talk about the holes under the emblem as well.
Old Sep 15, 2004 | 09:30 PM
GordoPanocho
The tailgate emblem has three holes behind it! It has to be attached somehow, right!? You can see behind the front grille emblem by opening up the hood, etc.
For those who need it, instructions for applying decals received from Ivan of zDecal.com are linked here: http://www.zdecal.com/store/instruction.html
Old Sep 16, 2004 | 06:03 PM
pornstar1969
i am talkin about the f-150 emblem on the tailgate not the ford
Old Sep 17, 2004 | 12:09 AM
Toreador's Avatar
Toreador
****, I also am curious about the F-150 emblem on back. I know the "Ford" oval has holes, but can the F-150 (and the side emblems) be taken off without having holes beneath them?
Old Sep 17, 2004 | 12:19 AM
xfordman's Avatar
xfordman
There are locator holes drilled in the metal. Thats so the guy on the assembly line can slap them on, and get them in the right place every time.
King Rex
Jan 31, 2014 08:11 PM
mudder460
Apr 14, 2012 01:42 PM
ashleymc
2004 - 2008 F150
Jun 2, 2009 02:13 AM
bigtexan99
Aug 15, 2007 03:04 PM
Ken2600
Oct 1, 2002 01:42 PM
