starting problems
Old Sep 14, 2004 | 05:52 PM
daerhldgs2's Avatar
daerhldgs2
starting problems
I have a 90 F150 with a rebuilt 302, with a duraspark II dist which I originally operated with a GM HEI module. The truck began to lose spark when starting on an intermittent basis, but when running it never quit. I replaced the coil which seemed to help for a time and also replaced many modules as well as coil wires and everything seemed the help for a while. I then replaced the hei module with a Mallory VIa box and replaced the pickup inside the dist. and the coil again, it ran with no failures to start for a few days and is at it again. When it has no spark there is power to the module and coil. Any ideas would be appreciated as I've replaced about all the ignition system, and still never know when I'll have spark when starting.
Old Sep 14, 2004 | 06:15 PM
boody101's Avatar
boody101
If there is no spark to the module and coil, check from there back to the ignition switch. (firewall plug for corrosion,ign. switch, etc.)
Old Sep 15, 2004 | 10:03 AM
daerhldgs2's Avatar
daerhldgs2
It always has power to the module and coil eventhough it may not make spark.
Old Sep 21, 2004 | 10:59 PM
swgaspidey's Avatar
swgaspidey
check your tps it could be going bad and causing the engine not to start.
Old Sep 21, 2004 | 11:21 PM
daerhldgs2's Avatar
daerhldgs2
I don't have one on this setup, it's propane and a duraspark dist.
Old Sep 22, 2004 | 12:31 AM
pfogle's Avatar
pfogle
Id make sure it's gettin fuel.. You're 100% sure it's not gettin spark......?
Old Sep 22, 2004 | 08:30 AM
lmadore's Avatar
lmadore
I'd have to agree with the fuel suggestion.
Old Sep 22, 2004 | 09:56 AM
daerhldgs2's Avatar
daerhldgs2
definitely getting fuel and I have been using my multi-meter to confirm power to the module and coil.
