Aerostar Ford Aerostar
92 Aerostar AWD drivetrain problem?
Old Jun 6, 2001 | 03:55 PM
ramm's Avatar
ramm
When the speed of 55-60mph is reached the van starts to Jerk. It
feels like a drivetrain problem. This "jerking" is so bad that I have to let off the gas for fear the transmission stock is going to be ripped off. The problem will arise at slower speeds (around 50 mph) if the van is under load, such as going up a steep hill. I also had a simular problem in the past, only at higher speeds (65-70mph) but after I took the van in for a recall repair it went away for a year or so. The recall was the S83 recall in which the rear half of the transfer case was replaced and also the driveshaft was replaced with an aluminum one.
Any Ideas?
Old Jun 6, 2001 | 05:47 PM
aerocolorado's Avatar
aerocolorado
Does it do this every time or just occasionally? On dry, hard surfaces or just on wet or muddy roads? A slack transfer case chain might react this way at speed as well as under load. Just a thought.
Old Jun 6, 2001 | 08:34 PM
ramm's Avatar
ramm
- (w/AWD) Powertrain bending resonance or transfer case output shaft bushing displacement can result in structural failure leading to fluid expulsion, driveshaft separation, or loss of vehicle drive. Corrective Action: Dealers will install a new transfer case rear output shaft bushing and an aluminum drive shaft
The above is the explantion for the recall a couple of years ago.As I stated before, I did have the problem before the recall, and it did go away after the recall was completed, but returned a couple of years later.
Yes, the jerking pretty well happens like clockwork around 57mph, or on a steep hill sooner. Since the problem went away once before when the rear half of the transfer case was replaced under the recall, I am wondering if there is something else wrong that is causing premature wear in the replaced parts.
Any replies welcome!
Old Jun 8, 2001 | 12:33 PM
aerocolorado
