Aerostar Ford Aerostar
Aerostar problem.
Old Mar 19, 2001 | 07:46 PM
Avanti's Avatar
Avanti
Aerostar problem.
Old Jun 3, 2001 | 02:06 AM
az_medic228's Avatar
az_medic228
Aerostar problem.
Hi All,
I hope this is the right area to post this, I am new to this club. I have a 90 Aerostar XL with a 3.0L The problem I am having with it is that after a while driving it under load, it starts to sputter and will die out. If I let it sit a while, it will start back up and Can be driven a ways then it will do the same thing again. Could it possibly be vapor locking? Or is it something else? The temp gauge does not go over half way when it does it either. Sometimes the "check engine"light comes on before this happens too.
Any help would be greatly appreciated!
Old Jun 3, 2001 | 09:52 AM
MarkP's Avatar
MarkP
Aerostar problem.
From my experience, it sounds like fuel pressure could be dropping off and the engine then stalls. A fuel pressure test would tell you that. But if the fuel filter hasn't been replaced in a while, you might try that first since it's a maintenance item anyway. The symptom also sounds like the electric fuel pump beginning to fail. To avoid spending allot on parts searching out the problem, a proper diagnosis needs to be performed to pinpoint if it's a fuel or ignition problem.
Good luck, Mark
Old Jun 3, 2001 | 10:11 PM
az_medic228
Aerostar problem.
Thanks Mark, I will do a pressure test on it Monday. I have replaced the fuel filter about a month ago, but did not think of the pump.
Old Jun 3, 2001 | 10:26 PM
MarkP's Avatar
MarkP
Aerostar problem.
When you do the fuel pressure test, keep in mind it may read normal even if the pump is on the way out. The fuel pump is cooled by the fuel flowing through it including it's motors brushes and armature. Often as the brushes wear out, the pump motor will run normally for a period of time and then just quit until it's had a chance to cool down. Also since the pump requires fuel to cool and lubricate it's pump parts and bearings, running the tank dry will ruin a good pump. A test during the time the engine won't start will reveal no pressure, but that time may be hard to catch. Good luck.
-Mark
> Thanks Mark, I
>on it Monday. I
> about a month ago,
>the pump.
Old Jun 14, 2001 | 10:10 PM
Ed's Avatar
Ed
Aerostar problem.
Another possibility may be a faulty MAP sensor. It could play a part in the symptoms you describe. Good luck!
Old Jun 14, 2001 | 10:15 PM
PyroManiak's Avatar
PyroManiak
Aerostar problem.
Other than this, the the van run good and have all its power?
