1978 - 1996 Big Bronco
pulling my hair out
Old Sep 14, 2004 | 08:53 AM
cr8ohc's Avatar
cr8ohc
Question pulling my hair out
i bought a 1988 bronco 4x4, with the inline six. real cheap. had a vacuum problem, fixed that, now i have a electrical problem. brand new battery, regulator, alternater, terminals. i am stuck and not very good at electrical work. what am i missing. the truck will start, ten minutes later it dies. so i thought alternator or battery. replaced both still not charging up. help
Old Sep 14, 2004 | 09:35 AM
BillyBob69's Avatar
BillyBob69
Check the ground on the other end from the pattery. If you don't have a good ground, then the engine will just die.
Old Sep 14, 2004 | 09:49 AM
Kemicalburns's Avatar
Kemicalburns
i agree with billybob. i would just replace the battery cables all together with some nice 4gauge wire. wirebrush the frame where the neg cable contacts this will insure a proper ground
late
laurin
6.7L Power Stroke Diesel
26
Nov 2, 2015 11:12 PM
jamaha51
Jan 10, 2015 06:38 PM
adam62
1997 - 2003 F150
Jan 9, 2011 09:22 PM
afinepoint
Electrical Systems/Wiring
Aug 27, 2009 07:27 AM
jjohnson
1997 - 2003 F150
Oct 9, 2006 10:17 AM
