1978 - 1996 Big Bronco
Good tire size?
Old Sep 10, 2004 | 05:09 PM
mspence's Avatar
mspence
Good tire size?
Just bought a 89 EB and it has the stock 235 75 r15 tires on it. What size tires will look good on this without getting a lift. The tires on it now look so anemic.
Old Sep 10, 2004 | 05:14 PM
Green Meanie 85's Avatar
Green Meanie 85
Talking
I have an 91 and it has 31x10.50 15 on it with plenty of room!!
Old Sep 10, 2004 | 07:37 PM
Blue'87GT's Avatar
Blue'87GT
Think those look anemic? Mine has some 165's on it! I can't wait to get some 31x10.50's.
Old Sep 10, 2004 | 07:43 PM
MatthewC's Avatar
MatthewC
165's!?!? That thing must SCREAM on highways?
Old Sep 10, 2004 | 10:45 PM
Jdenninger's Avatar
Jdenninger
i would go with a 31x11.50 or 32x11.50. 33's start to push the clearances. I've got 31's on my 79 and they almost look lost. i put 33's on my 89 and they filled the whole wheel well. The 89 looked good but was impratical and made the steering worse.
Old Sep 10, 2004 | 11:02 PM
mspence's Avatar
mspence
Will the 31s mess up the speedo or tach?
Old Sep 10, 2004 | 11:58 PM
greystreak92's Avatar
greystreak92
31's are about 1.7" difference in actual diameter than the 235's that came on the truck right out of the factory. Its not really enough to bother worrying with the speedo discrepancy. 32's or 33's may get you inot the need to recalibrate and more importantly, re-gear because they begin to push the engine out of its powerband. I had 33's with the stock 3.55 gears...ran like a bat outta hell but hill-climb and passing power sucked...fuel mileage went out the window too.
Old Sep 11, 2004 | 03:31 PM
Green Meanie 85
Talking
That's what i have 3.55's,i have an old set of turbines that came on my 79 F-150 sand box with 33in,so i might stick those on!!
Old Sep 11, 2004 | 07:18 PM
BOJOFASO's Avatar
BOJOFASO
bf goodrich all terrain ta 31,1050 15. the perfect set up
Old Sep 12, 2004 | 11:26 AM
raldo_gtm's Avatar
raldo_gtm
My 94 Bronco is a little anemic too. I have 235 75 15's and I was thinking about MT 31 10.5 15's either the Baja Claws or the Baja Radials. Does anyone have that setup? Please post a pic.
Old Sep 12, 2004 | 06:15 PM
Str0ud's Avatar
Str0ud
I'm going with Bojo on this one.
Str0ud
Old Sep 12, 2004 | 07:16 PM
StillaKilla187's Avatar
StillaKilla187
I think 31s or 33s would be the best sizes. For the brand I would get Bfg All-terrains
Old Sep 12, 2004 | 07:59 PM
aurgathor's Avatar
aurgathor
Looking at mine ('95) it appears to me that 32" is the max that can be installed without a lift. The front bumper need to be moved forward about 1" - 1.5"; however.
Old Sep 13, 2004 | 09:35 AM
BillyBob69's Avatar
BillyBob69
WHat BOJO Said, I run the same size on mine.
Old Sep 13, 2004 | 10:28 AM
ANdrewdrice's Avatar
ANdrewdrice
I have a 95 with no lift and no mods. I put 32-11.50r15 on. the only thing they rub on is the sway bars.
