Replacement headlights
Old Sep 13, 2004 | 08:31 PM
elemint's Avatar
elemint
Where can i find halogens to replace the weak sealed beams?
Old Sep 13, 2004 | 10:09 PM
Faithful Old Road Dog's Avatar
You can get the inexpensive sealed beam halogens or do a search for Hella. Maybe try Summit Racing or some online dealer. But before you do the upgrade you'll need to read whiter whites, brighter brights https://www.ford-trucks.com/article/...r_Brights.html
You'll save yourself the surprise later, especially if you're in the backwoods.
Old Sep 13, 2004 | 10:17 PM
Mil1ion's Avatar
Mil1ion
I bought a set of Bosch lights because of the pattern they use.
______/......._____/
as opposed to this pattern by other makers of lights
Old Sep 13, 2004 | 10:35 PM
4x4Subaru's Avatar
4x4Subaru
I replaced mine with Hella headlamps with 80/100 watt clear/blue lamps and also did the https://www.ford-trucks.com/article/...r_Brights.html
What a huge difference. I get alot of comps and also asked on how I did the fix. Anyway, that was my fix. Greg
Old Sep 14, 2004 | 03:09 PM
talisker's Avatar
talisker
I got a set of H-4 headlamps from J C Whitney and they are a whole lot better than the OEM lights. Not street legal but I have mnever had a problem.
Old Sep 14, 2004 | 05:17 PM
BB's Avatar
BB
Have you noticed if your headlight switch gets hot?
Old Sep 14, 2004 | 05:23 PM
talisker's Avatar
talisker
I more or less expected the switch and wiring to be inadequate. Part of the install was to wire in two driving lamp relays. The only thing the switch does now is activate the relays. Also if you want the headlights to perform at their best you need to supply them with full voltage. All of the wiring is 10 ga and goes from the battery, to the relay, to the headlights. No measurable voltage drop.
Old Sep 14, 2004 | 05:27 PM
BB's Avatar
BB
Ahh, thanks!
Sounds like a nice installation!
Old Sep 14, 2004 | 06:12 PM
BigBloo's Avatar
BigBloo
I installed Sylvania Silverstars in mine which I like a lot. Nice and white without that ricey bluish color.
Old Sep 14, 2004 | 10:56 PM
4x4Subaru's Avatar
4x4Subaru
Hey BB, I did the same relay setup. It works great. I even have the dims stay on with the brights. 100 watt lamps are very bright.
Old Sep 15, 2004 | 11:02 AM
BB's Avatar
BB
Hi 4x4Subaru!
Ya know I seem to remember that there was something wrong with the relay in the "whiter whites" tech article. Something about the way it was wired in or the connection labels, can't remember exactly.
Old Sep 15, 2004 | 08:16 PM
4x4Subaru's Avatar
4x4Subaru
Originally Posted by BB
Hi 4x4Subaru!
The wiring was right, everything went OK with mine anyway. I purposely wired the dims to stay on with the brights. That was in the tech article also.
