Exhaust Brake
Old Sep 13, 2004 | 07:37 PM
Goemons74's Avatar
Goemons74
Exhaust Brake
Hi
I was woundering if anyone has ever put an exhaust brake on a 300-6 before and if so did it work?
Old Sep 13, 2004 | 08:02 PM
srercrcr's Avatar
srercrcr
huh.......?
Old Sep 13, 2004 | 08:14 PM
benwantland's Avatar
benwantland
Have you ever seen an exhaust brake on a gas engine? They are not used, because closing the throttle blade(s) serves basically the same purpose (restricting infinite airflow through the engine)
Old Sep 13, 2004 | 08:38 PM
Phrogman46's Avatar
Phrogman46
You could put one on and when you closed and then reopened it there would be a huge back fire and it might even pop thrue the carb or TB. It's a Diesel engine thing only.
Old Sep 14, 2004 | 07:44 AM
gatesj's Avatar
gatesj
I think what you're talking about is a Jacobsen engine brake or "Jake brake". Not likely on your gas engine.
Old Sep 14, 2004 | 07:23 PM
kedwinh's Avatar
kedwinh
"They are not used, because closing the throttle blade(s) serves basically the same purpose (restricting infinite airflow through the engine)"
Not really true. An exhaust brake works by increasing exhaust back pressure not by cutting intake airflow.
Keith
Old Sep 14, 2004 | 08:08 PM
benwantland
Keith
I know, I was simplifying things just a bit....
And gatesj, an exhaust brake isn't the same as a jake brake.
Jake brake - opens exhaust valves at the TDC on compressoin stroke - usually used on med and heavy duty diesels
Exhaust brake - butterfly valve in the exhaust system - usually used on lighter duty apps
Old Sep 14, 2004 | 08:12 PM
Goemons74's Avatar
Goemons74
I guess putting a sliding Peace of metal with small holes that cuts off the exhaust wouldn't do much?
Old Sep 14, 2004 | 11:20 PM
Katmandu's Avatar
Katmandu
Talking
Originally Posted by Goemons74
Hi
Try it and report back to us!
Old Sep 15, 2004 | 06:25 AM
gatesj's Avatar
gatesj
You're right. I was thinking he was talking about a jake brake and I was trying to figure out how he was going to get the valves open on compression....
I would have to wonder if trying to fabricate some sort of homemade exhaust brake wouldn't blow manifold gaskets? How much pressure would build up?
Old Sep 15, 2004 | 03:09 PM
50_Buck_Work_Truck's Avatar
50_Buck_Work_Truck
Oh, Jebus! Talk about a Rube Goldberg mechanism! It'll be spitting and pooting back up thru the intake like a flat lobe on the cam! Probably FUBAR the carb-a-tooter too! It'll make for some interesting horse-chestnut-in-the-microwave popping noises under the air cleaner lid, however you slice it! Maybe upgrading the brakes on the vehicle might be a better solution!
afonda
Dec 26, 2008 01:56 AM
Dodge/Cummins
15
Jun 29, 2008 06:11 PM
hansshanks
Nov 12, 2006 12:15 PM
logan_85
Oct 6, 2002 06:10 PM
myst
Feb 25, 2002 09:26 AM
