86 f150 will not start
Old Sep 13, 2004 | 07:00 PM
86ford's Avatar
86ford
1st off I am no mechanic. Have a f150 5.0 engine. Was having problems starting, once in a while just wanted start. Now won't start at all. Went to advance said maybe your altenator or starter selenoid. Replaced the selenoid and took battery to get checked, battery OK. Put battery in and it just clicks, will not start. I would think it can't be the altenator now it must be the starter, am I correct. Terminals are all clean. Thanks for all the help Bill
Old Sep 13, 2004 | 09:46 PM
big hoss 29's Avatar
big hoss 29
Try replacing your cables, positive and negative. I had the same thing happen to my 86 F-250. I replaced the solenoid and it still acted up. I replaced the cables and said bye bye to my problems.
Old Sep 13, 2004 | 10:28 PM
82F1507.5's Avatar
82F1507.5
Click Click
Already replaced solenoid, battery is good....chances are you have a bad ground. I agree with big hoss 29, change your positive and negative cables. Be sure your new negative ground cable takes the same route as the old one. On many trucks the cable grounds first to the chassis then to the engine. Be sure all of your connections are clean and tight from the battery posts to the final terminal.
Old Sep 14, 2004 | 08:25 AM
lmadore's Avatar
lmadore
I just had that same issue. REPLACE THE CABLES AND CLEAN ALL CONNECTION POINTS.
Old Sep 15, 2004 | 08:23 PM
86ford's Avatar
86ford
I want to thank everyone for their help. Found out it was the starter. Thanks again
