New member
Old Sep 13, 2004 | 03:15 PM
jbnica's Avatar
jbnica
Unhappy New member
Hi there
I am a new member to the Web site.
I have a 1997 Explorer Eddie Bauer with 110K miles and I like to share a problem I have with my overdrive set up. The car shows the Off/Overdrive light (blinks)
and it rides rought. I can not bring it back to normal driving condition (to ovedrive). I have pushed the *** many times and the only difference is the RPM drops down, when I push the ***, but the car still drives rought and it waste gas a lot. Any suggestions, or is this one for the Dealer?
Thanks.
Old Sep 13, 2004 | 03:32 PM
4srco's Avatar
4srco
trans drive sensor
Check with an OBD II and see if a code shows. I had this same problem on my truck. Check the wiring hook up to your trans. Remove it clean it and replace. This stopped my blinking lite problem.
Old Sep 13, 2004 | 03:36 PM
jbnica's Avatar
jbnica
Thumbs up
Thanks for the reply.
What do you use the clean the terminals? Can I use brake cleaner in a spray can to desolve any oil or grease? I was also thinking that it could be due to the milage. Some cars have a reset bottom that resets some of the maintenance lights, and mechanics reset those after they perform some of the scheduled maintenance.
Old Sep 13, 2004 | 05:55 PM
Fordlover55's Avatar
Fordlover55
Still kicking!!
Welcome to FTE! If this doesn't take care of the issue, try our search engine or go to the Explorer forums. there you will find lots more info! Please take a few minutes and read the forum guidelines and the red notes at the top of each forum. They will help you along the way and make posting or finding info a lot easier!
Rightwire
New Member Introductions
Aug 15, 2009 12:40 AM
trapper_green
Jan 31, 2008 08:38 PM
cgill
May 23, 2007 10:50 AM
mlb44mag
Sep 6, 2004 02:17 PM
