Trouble with 2000 Ford Explorer
PO174 "System too lean Bank 2"
and the third was:
P1507 "Idle Air control under speed error"
Not sure what all this means. not much of a mechanic but the Mechanic i took the truck to twice has ran out of ideas as to what to do. He changed the fuel filter and checked for vaccum leaks and has found nothing. The check engine light is on for the third time and i'm a little hesitant to take it back to him. in the "notes" it says that he, "Cleaned the MAF sensor, Check the 1 AC motor - all tests OK but could be a soft code."
If anyone has any suggestions then let me know. thank you in advance.
trapper_green.
Let's get you hooked up with some folks that can help. Click on the Forums tab at the upper left and scroll down to the Explorer forum. If you scroll down further you can also find a forum for your engine. Post in those and I think you will get some help.
