Engine Temp While Towing
Old Sep 13, 2004 | 12:50 PM
DRWDreamin's Avatar
DRWDreamin
I towed my 5th wheel for the first time over the weekend in my '05 F350 DRW 4x4 with 4.10 gears.
On long or steep grades the engine temp would get hot, the fan would cycle on to cool it off and the temp would drop. This would happen on and off on long grades or near the top of a steep grade.
Anyone else notice this? I've heard of the fan cycling on and off in '04s but there was not a temperature change indicated on the gauge. I'm wondering if this might just be a gauge issue as I had no loss of power, or coolant leak or anything like that.
The truck towed great otherwise.
Old Sep 13, 2004 | 01:51 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
What is hot....pegged the guage...the fan is normal to go on and off
All I do is pulll and the fan thing is normal
Old Sep 13, 2004 | 01:58 PM
Daryl Hunter's Avatar
Daryl Hunter
By gauge change, how much change are you seeing?
It is rare to see any movement of the needle on my '03 on the engine or tranny gauge. I do have an outboard tranny gauge and I see movement on that - between say 165 to 200 deg F and the gauge in the dash doesn't budge.
I'd rather see some movement that honestly reflects the changes in temps that the vehicle is seeing. Maybe the '05 has fixed this shortcoming and has changed the gauge to be more reactive to changes.
Old Sep 13, 2004 | 02:22 PM
DRWDreamin's Avatar
DRWDreamin
It's a pretty major change. On flat land the gauge is basically right in the middle. Steep grades it hits the top line before the red line. The fan starts up at about 3/4 high and really starts making noice when it pegs. Temp drops to 1/2 again. That's basically the cycle I'm seeing up a hill.
The trans temp doesn't budge.
Old Sep 13, 2004 | 02:53 PM
Daryl Hunter
That doesn't sound right. Even if they did change the gauge sensitivity I would not expect it to move so high.
Have you checked the coolant bottle to see if it has been venting? This was a common problem with many folks. The bottle wanted to overflow if filled to the top fill line, but was generally not a problem if between low and midway.
If your radiator cap isn't holding pressure then I'd expect that you might be overheating. There have been a few guys who reported that.
Old Sep 13, 2004 | 03:05 PM
DRWDreamin's Avatar
DRWDreamin
My overflow bottle seems to be filled about as high as it can be... I wonder if that's part of the problem?
I will take a look. Thanks for the info.
Old Sep 13, 2004 | 03:27 PM
jdadamsjr's Avatar
jdadamsjr
If it is filled to the brim...
wonder if it's been filled with water or the "special" coolant required by ford.....
just a heads up, you might check that while you're at it...
Old Sep 13, 2004 | 09:11 PM
IB Tim's Avatar
IB Tim
You could have a bad sending unit.
Rubiconrod
6.2L V8
37
Sep 17, 2014 07:57 AM
gt350h
Sep 7, 2007 02:38 PM
tom in las vegas
Nov 19, 2004 09:18 PM
Horsecamper
Oct 28, 2004 11:01 PM
fishinbum
Oct 25, 2002 09:17 PM
