Sponsored by: Kumho
What causes camber problems?
Old Sep 12, 2004 | 06:44 PM
TexBand's Avatar
TexBand
Question What causes camber problems?
'91 F-150 2WD
General info question here:
What causes camber problems? You know, when the front wheels are all splayed out farther at the road than at the top of the tire when viewed from the front of the truck?
Ball joints and radius arm bushings don't seem to be excessively worn...at least they don't wiggle when I jack it up and shake.
Is this "hidden" wear? Or something else I should replace?
I just don't want to be screwed at the alignment shop.
Thanks,
Chuck
Old Sep 13, 2004 | 12:23 AM
SoCalDesertRider's Avatar
SoCalDesertRider
You've already checked the most likely culprit: ball joints. I-beam (axle) pivot bushings could be worn or the bracket that holds them could be cracked.
Old Sep 13, 2004 | 09:38 AM
nick88f150's Avatar
nick88f150
is your truck lifted? too much lift without readjusting will throw your camber off as well
Old Sep 13, 2004 | 10:54 PM
TexBand's Avatar
TexBand
No lifting for me.
I'll check the axle pivots and bushings.
Any other ideas while I'm at it?
Old Sep 14, 2004 | 12:24 PM
nick88f150's Avatar
nick88f150
nothin from me, i just know about the lift from reading about it on here...actually this is where i learn everything, haha. good luck
GraysonB97
1997 - 2003 F150
Jan 27, 2016 01:28 PM
Gregxlt
2015 - 2020 F150
Nov 12, 2015 08:46 AM
zlusmc
May 19, 2011 01:19 PM
stevenbhenry
Jul 8, 2009 10:10 PM
bandit990
Jul 21, 2006 03:21 PM
