Ford "cold shoulder"
Old Sep 12, 2004 | 05:59 PM
tezam's Avatar
tezam
Smile Ford "cold shoulder"
I have a 1987 Lincoln Town Car that lately has been stalling when cold. After warm-up, it’s okay. Since I don’t see a carburetor or choke to tweak, I’m wondering how this engine “chokes itself” until warm-up occurs (it is a 5.0 L, SEFI system with 165K miles). Although I have the Ford shop manual, it’s not clear enough to allow an understanding of the cold engine warm-up process. Anyone know which part(s) I should replace/tweak/adjust (TPS vs EGR vs Air Bypass Valve)?
Old Sep 12, 2004 | 07:12 PM
EPNCSU2006's Avatar
EPNCSU2006
Here's a good website that might help explain EFI a little better: http://fordfuelinjection.com
The computer takes the input from the coolant temp sensor and air temp sensor and richens up the mixture until it senses that the engine is warm. That's the short version, the actual fuel strategy is a little longer, but that's basically what happens.
Old Sep 13, 2004 | 08:54 PM
LxMan1's Avatar
LxMan1
I would replace the IAC, It is usually the culprit. It controls the idle speeds hot and cold.
Old Sep 14, 2004 | 05:23 PM
tezam's Avatar
tezam
LxMan1;
Thanks for the reply. I just looked through my shop manual and could not find a reference to the "IAC." Can you tell me what IAC stands for and where it is located?
Jerry in VA
Old Sep 15, 2004 | 02:31 AM
Ford_Six's Avatar
Ford_Six
Idle air controller, also reffered to as the idle air solenoid, or the air bypass valve, and it is located on the throttle body. Fairly accessable, there are only two bolts that hold it on, and one connector.
Old Sep 16, 2004 | 06:18 PM
LxMan1's Avatar
LxMan1
Yep, it is on the rear of the throttlebody on your car. It is held on by two 8mm socket headed bolts. It has a round cylinder on it with a 2 wire plug. It takes about 5 min to change if you don't drop either bolt down behind the engine
Old Sep 17, 2004 | 03:47 PM
tezam's Avatar
tezam
LxMan1/Ford_six;
Thanks for the information on my Lincoln cold-start problem. I replaced the IAC/ABV and the problem disappeared. Good advice...
Jerry
bertolina
19
Jan 1, 2015 09:22 AM
nuwave
May 31, 2007 09:06 PM
352 blue
13
Nov 22, 2004 02:32 AM
Coneynew
Feb 27, 2003 07:19 PM
steve1999
Nov 6, 2001 11:00 PM
