Sponsored by: Real Truck
how much lift
Old Sep 12, 2004 | 02:57 PM
Rumblurr's Avatar
Rumblurr
how much lift
just wounder about what the lift would need to be on a 2000 250sd 4x4 with x springs to get these not to rub toyo open country AT LT355/60R20 125R. the tire measure about 36.8 " or if anyone could tell me what the best tire that will fit under the truck none lifted also.
Old Sep 12, 2004 | 04:12 PM
southernfordman's Avatar
southernfordman
4inch or 6inch
Old Sep 12, 2004 | 04:47 PM
02superstroker's Avatar
02superstroker
i would go 6.. or 8
Old Sep 12, 2004 | 04:55 PM
Todder's Avatar
Todder
I would put a 6" on for anything over a 35" tire. 8" for over 39"s.
I might do a 4" with 35"s on my truck still haven't decided yet though.
Old Sep 12, 2004 | 05:29 PM
2000silverbullet's Avatar
2000silverbullet
I'd go 6. I have a 6.5 inch with 37's and it rubs only when full lock left/right with some articulation.
Old Sep 12, 2004 | 06:33 PM
DCSpecial's Avatar
DCSpecial
At minimum to run those Toyo's a 6"......and you may still experience slight rubbing depending on wheel selection and the 355mm width. 7-8" lift would clear them better.
Biggest tire for a stock truck with x springs would be 33/12.5 IMO.
Hope this helps.
Old Sep 12, 2004 | 06:51 PM
{OF}Smiley's Avatar
{OF}Smiley
Put Bushwacker Cutouts on with no other lift since you already have the small lift from the x-springs.
If I had known how much larger the openings would be with my cutouts on I would have just run the above setup with my 38 PJs with my x-springs and no additional hanger lift.
WindLight
2009 - 2014 F150
Mar 12, 2010 07:26 PM
Mr.BrrIce
2004 - 2008 F150
17
Sep 14, 2007 06:28 AM
Ford94Bronco4x4
1978 - 1996 Big Bronco
Apr 23, 2006 09:31 PM
NitrousAl
Aug 21, 2005 06:50 AM
bunnycop
Jul 7, 2005 11:23 AM
