Sponsored by: Auxito
1999 F150 Codes
Old Sep 12, 2004 | 01:49 PM
wrongwrench's Avatar
wrongwrench
Thumbs down 1999 F150 Codes
Went to the local "ADVANCED AUTO" store where the manager plugged in to retreive the codes below on my truck. The check engine light was on. I need help figuring out what to buy or do to make the light go off.
Codes: Vehicle Scanned
Global OBDII
Vehicle
DTC (CODES)
PO174
System Too Lean
(Bank 2)
DTC Pending (Codes)
PO171
System Too Lean
(Bank 1)
Okay, is this something the DYI can do? Or do I have to send into a Ford Dealer $$$????
Old Sep 12, 2004 | 02:19 PM
AegisSailor's Avatar
AegisSailor
Here is what the manual has to say:
HA41 DTCs P0171, P0172, P0174 AND P0175: FUEL SYSTEM AT THE CORRECTED FUEL TRIM
HO2S DTCs Reference list:
HO2S-11 = DTCs P0171 and P0172
HO2S-21 = DTCs P0174 and P0175
Check intake air system for leaks, obstructions and damage.
Check air cleaner element, air cleaner housing for blockage.
Verify fuel level.
Verify integrity of the PCV system.
Check for disconnected spark plug wires.
Check for vacuum leaks.
Verify customer did not run out of fuel
Old Sep 12, 2004 | 03:17 PM
wrongwrench
Thanks Aegisailor, will print out what you wrote and go do an inspection. Will let you know what I did or didn't find.
Old Sep 12, 2004 | 06:49 PM
wrongwrench
Roger: Thanks for getting me those codes. I printed them and went to my 99F150. Started to look at various hoses, etc. I finally found one small hose that had a small crack in it causing the leak! Went to Advanced Auto (Usually go to AutoZone but the counter was full and the Advanced guy originally read the codes for me) and bought some Ventilation high temp hose, cut it, and replaced the bad section. Also bought a new air filter. Took battery cable off, installed parts, and cranked her over. The check engine light went off. I started and stopped her about 3 more times and no light! Hope that takes care of it until something else goes on this 178,000 mile truck.
Thanks for your help and thanks to whoever started this website! Very helpful!!!
Unklebob
Modular V10 (6.8l)
Feb 10, 2015 06:23 AM
Shoob36
Mar 5, 2012 11:54 PM
FordMan10
1997 - 2003 F150
Aug 30, 2010 12:22 AM
kcmark
Oct 6, 2009 08:20 PM
