1997 brake lights
Old Sep 12, 2004 | 12:00 PM
dtrag's Avatar
dtrag
1997 brake lights
The brake lights on my f150 (1997) are out and the ABS light on the dash is flashing.
I have replaced the pressure sensor on the brake pedal and the brake lights. I have checked the fluid in the master cylinder and checked all of the fuses.
What next?
The hazard flashers, reverse lights and turn indicator lights all work fine.
Thanks in advance for your help.
Old Sep 12, 2004 | 06:33 PM
Dealford's Avatar
Dealford
Welcome to FTE!
Check the fuse box in the cab. The brake light fuse may be combined with other systems on one fuse. In my 97 Ranger, it's fuse space #13.
AL.
Old Sep 12, 2004 | 09:51 PM
dtrag's Avatar
dtrag
Thanks Al,
I have already checked the fuses. Any other ideas?
Peace
Old Sep 12, 2004 | 11:25 PM
Muffinman's Avatar
Muffinman
When your brake lights stop working the ABS light will flash. Check your lamps all the way around.
Old Sep 13, 2004 | 04:41 PM
baredog26's Avatar
baredog26
I believe that your brake lights go through your multifunction switch. If your third light works and the other two don't I would replace it
Old Sep 13, 2004 | 05:44 PM
dtrag's Avatar
dtrag
Thanks for your reply. Where is the multifunction switch and what does it control?
The only lights that dont work are the brake lights. Both the hazard and turn indicators work.
thank you again
Old Sep 14, 2004 | 11:49 AM
baredog26's Avatar
baredog26
the multifunction switch is your turnsignal switch, located on the steering column. It controls your wipers and your turn signals, but your brake lights run through it also. If your truck has a third brake light make sure that it is working. If your third brake light is out also than your multifunction switch is not the problem.
Old Sep 14, 2004 | 08:51 PM
HomerWinzlow's Avatar
HomerWinzlow
Is there power going into the brake lamp switch and is there power coming out of the switch when the pedal is depressed? If the wiring is broken going to the switch then the fuse would be good but switch is not getting power, or not transmitting power through the brake circuit. Look at the wiring closely, especially right at the connector to the switch.
