No dash lights?
Old Sep 14, 2004 | 10:01 AM
greentools's Avatar
greentools
No dash lights?
I have a 1986 f250. I can't get the dash lights to work. I have already replaced the headlight switch and it did'nt work. Is there a relay under the hood for this? Thanks!
Old Sep 14, 2004 | 08:57 PM
HomerWinzlow's Avatar
HomerWinzlow
I presume you checked all the fuses before you did anything. Next step would be to check and see if the wire from the switch is getting power when you turn the switch on. Always possible the bulbs have all burned out too.
