Stalling when come down from higher RPM
Old Sep 11, 2004 | 11:34 PM
yukoner008's Avatar
yukoner008
Hello, <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
I have a 1994 F250 with a 7.3l turbo diesel and it has been great. But over the last few weeks it has started to stall when the RPMs drop from about 2000RPM or higher. It starts and ideas without any problems. It is a big problem when you are slowing down to turn and engage the clutch and rpms drop it Stalls. This seems very odd as it only happens when the RPMs are up over 2000, and only when they come down fast. If the RPMs come down slowly it is OK.<o></o>
Any suggestions?<o></o>
Thanks
Old Sep 12, 2004 | 12:10 AM
ltfox's Avatar
ltfox
Same thing happened to my old mans 94 idi turbo. After a bunch a useless worring it ended up being a fuel filter. problem fixed. i hope this helps.
Old Sep 12, 2004 | 07:11 PM
Rg3720's Avatar
Rg3720
you can try installing a fuel filter, but most times it will not help, i will tell you how to fix this problem if the filter dose not help, reamove the filter empty it fill it with atf, mercon dextron, a lot of people will tell you this is not good, im telling you it works, i have worked on these engines since they went in to production, you may half to repete this a couple of times, your outher choice is anouther pump anyway, the problem the govoner weight assembly is varnished up and is sticking.
Old Sep 12, 2004 | 11:34 PM
Spectramac's Avatar
Spectramac
Yeah, it's the inj. pump. Can't hurt, give the atf a try. Usually once they get bad they're too scored to save but....
Old Sep 13, 2004 | 05:37 PM
Logical Heritic's Avatar
Logical Heritic
Might try marvel instead. Its the friction modifiers that are bad.
Old Sep 13, 2004 | 05:48 PM
yukoner008's Avatar
yukoner008
Thanks
I tried a new filter and that didnt help. I will try the atf and let you know how it works out. Then maybe a new injector pump.
Thanks for all the help.
Old Sep 17, 2004 | 06:25 AM
BigGunZ's Avatar
BigGunZ
Turn up the idle screw (if equipped). Mine does the same thing every other year or so. The idle backs down due to vibration over time. I have fixed this exact problem on mine 3 times within the last 6 years by just turning up the idle slightly.
Old Sep 17, 2004 | 09:42 AM
351M's Avatar
351M
You forgot to mention that he only needs to do that if it is idling below 750 Rpm I think.
Old Sep 20, 2004 | 12:12 PM
BigGunZ's Avatar
BigGunZ
You would think but mine appeared to idle normally. It took only the slightest upward bump to correct.
Old Oct 7, 2004 | 09:29 PM
yukoner008's Avatar
yukoner008
ATF did the trick
Hey thanks for all the replys. I ran two tanks through with ATF fluid in them and it now is running great:-)
Old Oct 7, 2004 | 11:49 PM
89ford73's Avatar
89ford73
i use 2-stroke lawn mower oil, but atf works just as good i guess. its cheaper too.
ford-runner
Nov 4, 2011 03:11 PM
bhirtz
Aug 27, 2011 02:38 PM
Mochosla
Jul 23, 2011 11:14 AM
dillehay
Aug 16, 2010 10:29 AM
Grogan14
Sep 16, 2007 08:41 PM
