Sponsored by: Kumho
Need help with spring modification...
Old Sep 11, 2004 | 08:41 PM
Scouder's Avatar
Scouder
I have a 76 F250. It is very customized (see gallery). It currently has SkyJacker softride leafs all the way around. The problem I have is that the truck is MUCH lighter (4600lbs) than it used to be, especially on the front axle, and will never tow or haul anything again. I would like to soften these springs up some more, specifically so the truck will weight transfer better under hard acceleration, improving rear axle traction. It currently has a 60/40 weight balance, so it has the potential to load the rear tires if I get the springs right.
The question is, can I just remove (or have removed) some of the leaves from the spring packs?
-Scouder
Old Sep 12, 2004 | 08:57 AM
mark a.'s Avatar
mark a.
I would call Sky Jacker & ask them.
