oil
Old Sep 11, 2004 | 02:35 PM
t.j.g.'s Avatar
t.j.g.
oil
new to diesel i getting ready to change oil in my 2000 7.3 sd c/c
i bought the truck used so i dont know if it has regular oil or synthtic oil in it ( 70,000 )
i am tinking or going with synthtic what do you all think also it will be winter soon here in minnesota
can i get by using 10w-40w or should i go with 10w-30w !
i dont use my truck very much being i have a company vehical i use for work
thanks for your opinions
Old Sep 11, 2004 | 03:00 PM
eri64's Avatar
eri64
5w40 synthetic diesel rated chevron Delo, Mobil Delvac 1, valvoline premium blue extreme ,petrocanada duron - this one IMHO the best
Old Sep 11, 2004 | 03:23 PM
Pikachu's Avatar
Pikachu
Every big rig I ever owned was changed over to Delvac1 as soon as I could do so. Without exception, fuel economy improved, oil consumption decreased and overall cost of ownership went down. My last rig had a 3406E 475 hp Cat, and by performing oil analyses, I was able to extend the drain interval to 100,000 miles. I know this is just one of the oils available, but I swear by the Delvac1.
Old Sep 11, 2004 | 04:29 PM
eri64's Avatar
eri64
Yes you can't really go wrong buying delvac1 but it's expensive ,there is direct comparision test done by SAE between delvac1 and duron , and they equal in all the test ( you can find this test on the web ), petrocanada duron is half the price. But delvac1 is excelent choice, if money is not a problem
Old Sep 11, 2004 | 07:24 PM
t.j.g.'s Avatar
t.j.g.
but would it be alright to run 15w-40w throught the winter in minn it can get to -20 but usually stays above 0 or should i put in 10w-30w
Old Sep 11, 2004 | 08:08 PM
slc10844's Avatar
slc10844
If you use the 15w-40 in the winter you might have hard starting due to the oil thickening. 10w-30 would be a better choice. Just make sure it is CH-4 or CI-4 rated. In either case, if the truck has the original batteries you might want to consider replacing them before winter. They are getting near the end of their useful life.
Old Sep 12, 2004 | 09:09 AM
t.j.g.'s Avatar
t.j.g.
thank for the info
