highway rpm's
Old Sep 11, 2004 | 07:37 AM
Peach's Avatar
Peach
highway rpm's
I have an 87 f150 with a 3 speed transmission. I've been doing some searches on this site and it seems my rpm is much higher than it should be. Its about 2600 at 55 mph. Can anyone tell me if this is about right, and is it hurting my engine?
Old Sep 11, 2004 | 08:09 AM
alabamabuddog's Avatar
alabamabuddog
with the 3 speed tranny that might be right. The teling factor would be gas mileage. What are you getting at hwy speed?
Old Sep 11, 2004 | 09:39 AM
Peach's Avatar
Peach
i think about 12 mpg
Old Sep 11, 2004 | 11:53 PM
masterbeavis's Avatar
masterbeavis
My opinion is that your RPM range is fine. When you start getting up past 4000 RPM, then id get concerned. Other than that, I would just turn up the radio, check the fluids under the hood once in a while, and leave good enough alone. :P
Old Sep 13, 2004 | 08:04 PM
jamiesan's Avatar
jamiesan
what's yor gear ratio? How about tire size?
Old Sep 13, 2004 | 08:52 PM
FilmGuy's Avatar
FilmGuy
I have the opposite problem.. with the combination of tall tires, and 3.55 gears, I don't hit 2000 rpm in fifth gear until I am going 63 mph... that in conjunction with a barely adequate 5.0 engine with little low rpm torque and the heavy chassis of the f-250, makes 5th gear useless for 95% of the driving I do... 4.10's would set me up nicely...
Old Sep 13, 2004 | 09:04 PM
F150'89's Avatar
F150'89
I have a '89 F150 302 w/5sp and at 70mph engine RPM's is 2500 and MPG is around 12 {sucks gas}
Old Sep 14, 2004 | 10:21 AM
alabamabuddog
F150"89 that seems a little low. I have 3:55 geard. Whats yours.
Old Sep 14, 2004 | 02:46 PM
Missileman740's Avatar
Missileman740
Peach,
Your rpm is right on for a C6 transmission and 3.55 gears in an 87.
Old Sep 14, 2004 | 05:06 PM
Peach's Avatar
Peach
alright, thanks guys
Old Sep 14, 2004 | 09:21 PM
F150'89's Avatar
F150'89
My axle code is "19" and according to the spec's listed on FTE that is a 3.55 gear. Tire size is 235/75/15 on stock spoke rims.
Old Sep 16, 2004 | 06:23 PM
F150'89's Avatar
F150'89
Slid under the F150 today and looked at the ID tag and its a 3.55
f100mudder81
13
Aug 15, 2019 05:06 PM
61 uni
28
May 27, 2016 02:09 PM
Slimsadie
13
Aug 18, 2009 10:20 PM
2jhanna
Nov 5, 2006 09:22 PM
ovaltrack
Dec 24, 2004 12:19 AM
