I purchased a new water pump from shopdiesel. Pump works great but im installing a coolant filter and the plug on the side of the pump is what i understand to tap into.
My question is what size is the square plug suppose to be, a 3/8's socket is to big and a 1/4 is to small.
Is there a square driver that fits this or is my plug the wrong size.
They do make sockets for square drive plugs. It is probably 5/16". I have a set of the these sockets at work. I originally bought them to remove the oil galley plugs on engines I was rebuilding. I too am also going to install a coolant filter, but have not checked on the size of the plug. I have purchased everything but the hose needed. Right now, time is not my friend. Seems to be becoming a winter time project. I call my truck "Big Red" too.
Try your local auto parts or hardware store. I got my set from Snap On many years ago. BTW, My waterpump has an external square drive plug. I'm sorry I can't tell you the exact size you will need for yours.
If the plug's not too tight, you could grind the opposite 2 points off of a bolt with a 5/16" head bolt and make a tool. You then could maybe break it loose with visegrips on the bolt shank. Another idea! Get a piece of bar/key stock and turn it with a wrench.
Guys, just use a long 1/4" drive extension they fit great... Edit here, I just read where you said a 1/4" was too small. I have a snap on that fits mine perfect. Might make sure that yours is not grown up with something on the inside of the drive square. The 1/4" extension fits mine to a "T"...
I bought a small 11mm open end wrench @ Sears. (Cost about $10) A little bit of a tight fit but, it worked. Never thought about trying the 1/4 extension ! I kept the plug after I installed my coolant filter. I'm going to go see if my extension fits just out of curiousity.
You going to change yours over to the Gold Coolant ? (If you had the Green) Great time to do it and you can ditch the SCA's.
