Hey There Locknkey
Old Sep 10, 2004 | 05:47 PM
reamer's Avatar
reamer
Hey There Locknkey
Do you have a name and model number fot the code reader at Walmart?
The one where you don't have to listen for the beeps?
I looked all over at the local Wal Mart....No luck. Should it be in Auto section or somewhere else?
Thanks
Reamer
Old Sep 11, 2004 | 01:10 AM
locknkey's Avatar
locknkey
The code reader I haveis for models 1981 to 1995, for FORD OBD 1. EEC IV and MCU Domestic vehicles. It is model 3145 .
Its yellow an black color. I don't see a manufacturer unless its a INN (R) VA (R).
I had found it near the floor area where the sparkplugs are, some were hanging on the wire loom and they were all in that location. When you look at it, it'll have a small screen that if you tilt the package, you can see its a digital model. (had the flashing beepin light model before, but couldn't keep up with the flashes when I blinked)
This model also will take a 9v battery in the back so buy one of those too as it doesn't come with one. The instruction manual is pretty thick but its in multi languages and it explains alot about what you should be looking for when pulling the codes for the computer. If you don't get any codes, more than likely you'll have to replace the main computer. Post your results.
Old Sep 11, 2004 | 06:14 AM
reamer's Avatar
reamer
Great Thanks!
Is th emain computer the EEC? are they still available? do you know how much?
Thanks
Old Sep 11, 2004 | 10:20 AM
locknkey's Avatar
locknkey
Reamer, Yes to both questions, around here the EEC computer is around $100.00 reconditioned, with exchange of the old one...but theres no point in getting another one unless you can't retrieve the codes in the first place..
