i have a 1992 f150 with a sright 6 300 motor in it with a five speed transmission and i have a 1984 351 windsor that i want to put in it. my question is, will it bolt up to the five speed transmission . thanks for your help.
The 300 has the same bolt pattern as a 351M, 400, 429, and 460. The 351W has the standard small block bolt pattern, so the bellhousing won't work. If the housing is a bolt on piece, you should be able to get one that would work, just need to know the length of the input shaft so you're not putting pressure on the tranny's front bearing.
Actually, it is the other way, the 300, 289, 302 and 351W use the same bell, the M's will trade with the 460's but not the 300.
