Cam and efi...humm
Old Sep 10, 2004 | 09:12 AM
wozxxx86's Avatar
wozxxx86
Cam and efi...humm
i called up comp cam and asked for a cam that would have realy low end TQ and they told me that it would have to be custom ground. i asked them about a cam that i was looking at earlyer, part # 35-413-8 and they said that that wouldnt work with efi cause there wasnt enought lob sep. i didnt think that materd with maf.. is there anyother cam on there from the extreme energy line that will work with efi?
Old Sep 10, 2004 | 09:41 AM
EPNCSU2006's Avatar
EPNCSU2006
Did you tell them you have installed a MAF conversion? Stock '88 is not MAF.
Old Sep 10, 2004 | 09:43 AM
wozxxx86's Avatar
wozxxx86
yes, i told them the motor was a 92 and that i was putting mass air on it, the lobe sep on that cam was 110.
Old Sep 10, 2004 | 09:48 AM
EPNCSU2006's Avatar
EPNCSU2006
I don't know what the deal is in that case.
Old Sep 10, 2004 | 09:51 AM
wozxxx86's Avatar
wozxxx86
well then, mayb i should ask what cams other people have used in my case(351w MAF) and not had problems.
Old Sep 10, 2004 | 05:17 PM
jwtaylor's Avatar
jwtaylor
Many many efi 5.8 users run the comp cam 35-255-5 cam and report it makes great low end torque in truck applications, thats with speed density so it would work just as well with your mass air. later
Old Sep 11, 2004 | 09:48 AM
wozxxx86's Avatar
wozxxx86
im pretty sure i cant run roller lifters with that can i? cause that what id like to run
Old Sep 11, 2004 | 09:55 AM
P51D Mustang's Avatar
P51D Mustang
The Crane E303 is 110 lobe seperation, but it will have a surging idle even with mass air. That's probably why they don't think it will work, because of poor idle quality.
Old Sep 11, 2004 | 10:05 AM
wozxxx86's Avatar
wozxxx86
i havent talked to crane yet, the only people ive talked to is compcam, and they sound more happy to get me off the phone lol
Old Sep 11, 2004 | 10:39 AM
jwtaylor's Avatar
jwtaylor
The 92 5.8 blocks weren't roller capable as in, you could drop any off the shelf roller cam in and use 5.0 hardware.
You can change the distributor gear and run a reduced base circle cam, with stock 5.0 roller hardware or get linked roller lifter and a standard cam w/t a different distributor gear.
I wouldn't worry about it and run the flat tappet but thats me. Good luck
Old Oct 21, 2004 | 04:31 PM
wozxxx86's Avatar
wozxxx86
so other then poor idle thats the only thing that you could see thats wrong withh 110 lobe sep? if so i'll order the cam ina couple days.
Old Oct 21, 2004 | 04:59 PM
jwtaylor's Avatar
jwtaylor
I mentioned this previously, do you have an F4TE block? 1993 1/2 and later.
If your 92 351w block is oem then its not roller compatible.
The E cam or any other off the shelf roller camshaft will not work in a nonroller block, unless you get crane retrofit lifters $419 and possibly change the distributor gear, specific to camshaft, if not specific to the cam then your gonna have problems. YOu could opt for a reduced base circle camshaft, change the distributor gear per the cams needs and use the oem 5.0 hardware.
The flat tappet camshaft I recommended previously 35-255-5 (comp cam) is one many of the first generation lightning owners use, it is flat tappet but it is also efi friendly. They report it makes nice low end torque...thats what I have heard as I haven't used it. They refer to it as the hot rod cam.
later
Old Oct 21, 2004 | 05:13 PM
wozxxx86's Avatar
wozxxx86
ok the cam im looking at isnt a roller, ive steered away from that, i was just wondering about the lobe sep and efi for this cam, which is the non-roller equivalant of the roller that i was lookin at.
Old Oct 21, 2004 | 05:22 PM
jwtaylor's Avatar
jwtaylor
Are you talking about comp cams 35-413-8 ?
Old Oct 21, 2004 | 05:23 PM
wozxxx86's Avatar
wozxxx86
oo, ive been usin desktop dyno and the cam, grind 35-320-3, which gives a power curve lower down and more TQ
