vibration and slow pickup
Old Sep 9, 2004 | 03:29 PM
dr worm's Avatar
dr worm
Question vibration and slow pickup
my 02 explorer when idleing shakes alot and i have slow pickup off the line.last week i changed the pluges and cleaned my k&n fipk filter i thought maybe the oil got in the throttle position sensor so i cleaned it still no better what could it be ?
Old Sep 9, 2004 | 06:55 PM
trike1946's Avatar
trike1946
Although the plugs and wires are supposed to last, mine did the same thing. I had a bad wire. I changed all the plugs and wires and was good to go. Mine is a 97 with a 5.0. There were three dirrerent wire sets for that vehicle, all slightly different. And there was no room to work. It can be done. Do you have an inline fuel filter? Might change it if you do. Good luck with it.
Old Sep 10, 2004 | 12:07 AM
87 XLT's Avatar
87 XLT
If your K&N contaminated anything it would be the MAF sensor. If you dont want to pull the trouble codes yourself, Autozone will do it.
Old Sep 12, 2004 | 01:14 AM
peabody01's Avatar
peabody01
k&n air filters are bad about contaminating maf sensors. I would probably start there. I have replaced a lot of contaminated maf sensors because of those filters.
dmanshane
Dec 28, 2012 11:16 PM
79fordf250pickup
Feb 8, 2012 11:28 PM
Talyn
306
Sep 12, 2011 10:39 PM
imasimpleman
1983 - 2012 Ranger & B-Series
Jun 12, 2010 05:48 AM
BUBBEC
Jul 21, 2005 09:46 PM
