Shock question - help.
Old Sep 9, 2004 | 12:11 PM
Missileman740's Avatar
Missileman740
I have an 87 F150 4X4 XLT Lariat with the factory towing package. The front IFS has two shocks on each side. It is all factory installed, the shocks are original with Ford part numbers on them (yes, they need to be replaced). Since this truck never sees offroad, what shocks do I replace with? Will using only one shock on each side be adequate, and if so do I mount it on the front shock position or the rear shock position?
Thanks to all in advance for your input.
Old Sep 10, 2004 | 12:49 AM
beerinside's Avatar
beerinside
I would just spend the $25 each for Monroe replacement shocks. Always do a job right the first time.
Old Sep 10, 2004 | 06:33 AM
quincyjr's Avatar
quincyjr
you need to replace all for shocks on the front at the same time.
Old Sep 10, 2004 | 08:09 AM
Crazz's Avatar
Crazz
i use monomax on mine, they have been awesome. the ride has been great. there bout 50 bucks each well if you get the best shock they offer which is what i did, buy 3 get one free ;p but there ride is great
Old Sep 11, 2004 | 09:56 PM
SoCalDesertRider's Avatar
SoCalDesertRider
You can run just 2 shocks on there if you want to. Just get shocks for a standard single-shock truck. Mount them in the rear position.
