Sponsored by: Auxito
turn signal problem
Old Sep 9, 2004 | 12:39 AM
98 4.6 locked up's Avatar
98 4.6 locked up
turn signal problem
When I use my turn signals they blink really fast and outside signals don't work. If I hold the turn signal on but dont lock it in position, all works good. Only happens when you lock it in. It sometimes even works normal when locked in, but not very often. Does this sound like a bad multi function switch? Any tips on replacing? Thanks Jordan
Old Sep 9, 2004 | 08:56 AM
RoyalFord's Avatar
RoyalFord
I had this problem when I first bought my truck at 65,000 mi. When I took it for a test drive it did it and I thought a bulb was out, but they were all good. But ever since it hasn't happend. I guess since it was sitting around at the dealer it got a little "dusty" and the more I used it the better it got. I don't know what you should do to fix though. Probably something on the steering column.
Bryan
Old Sep 9, 2004 | 09:06 PM
Racerguy's Avatar
Racerguy
It does sound like a bad multifunction switch.
They are easy to replace.
If you search in here you'll find instructions for it.
Basically you remove the steering column covers, 2 connectors and 2 screws.
Old Sep 14, 2004 | 12:19 AM
98 4.6 locked up
Thanks for the replies. The truck did sit for a long while before I bought it. But the problem doesn't seem to be going away.
Old Sep 14, 2004 | 12:47 AM
Rebel79's Avatar
Rebel79
I have a similiar problem, but opposite. Sometimes when I use my right blinker without locking it, I hear it click really fast, and there is no light on my dash. But if I lock the blinker, it starts working.
Old Sep 14, 2004 | 09:04 AM
BillyBob69's Avatar
BillyBob69
The flasher relay could also be going bad. They can fail either by blinking really slow or blinking really fast. Cheap and easy to replace. Not a bad place to start.
Old Sep 18, 2004 | 07:55 PM
danhannah's Avatar
danhannah
Also,
I found my really fast blinking problem NOT in a burned out bulb, but in dirty and muddy trailer light wiring near the back tailgate.
Cleaned it all up and resealed it - no problems.
Did you notice there are different fuses for the trailer lights than for the truck tail lights and blinkers?
Dan
Old Sep 20, 2004 | 08:37 AM
BillyBob69's Avatar
BillyBob69
With the factory tow package in use..yes there are different fuses. Most after market taps right into your existing tail lights and such...so they aren't on a seperate fuse.
