Cheapest oil change?
Old Sep 8, 2004 | 08:40 PM
lombardo96's Avatar
lombardo96
I went and got my oil changed at my local dealer and nearly got in a fight. Let me start by telling you my truck is lifted 8" and while I was waiting for the dealer to finish it was taking over an hour and a half when they told me it was going to take only a half hour. when I walked around the corner to see if they finished my truck I catch this idoit standing on my bumper with dirty shoes and nothing covering my bumper with my truck not even on the lift. To make a long story short they scratch my whole bumper and the lesson I learned was to start changing my own oil. My question is for you do it yourselfers. where is the cheapest place to buy diesel oil and oil filters so I can change my own oil? I thank you in advance.
Old Sep 8, 2004 | 09:32 PM
npccpartsman's Avatar
npccpartsman
If I was you the cheapest place I'd be gettin my oil changed was at the dealership that messed your bumper up--LIFETIME. geez, and I thought my place was BAD. but seriously? Do a search through this forum--there's tons of opinions on this very subject. you should be able to get an engine oil filter for less than 20 bucks and depending on the oil from 6/gal to 4/qt. It's all about your personal preferences. Good luck and welcome to a great site
Old Sep 8, 2004 | 09:40 PM
Rick Braden's Avatar
Rick Braden
Go to www.filter1.com. You'll get the same oil filter as from the dealer for under $12.00. If you get about $40 or so of filters etc the shipping is free & no tax. How can you do better than that. A lot of people go to Wall Mart for oil. Take care.
I really don't like other people working on my stuff either. Way too many times there prime concern is how quickly they can do the job instead of how well they can do the job. Rick
Old Sep 8, 2004 | 11:57 PM
Motown Fire's Avatar
Motown Fire
www.filter1.com for the filters and Sam's Club for the oil. I buy a case at a time of Rotella, it runs right at $35.
Old Sep 9, 2004 | 06:09 AM
SBV45's Avatar
SBV45
Take a look at my instructions at http://home.austin.rr.com/sbv1/Proce...gEngineOil.htm. Get a Fumoto Valve. Get your oil at WalMart and filters at www.filter1.com or http://www.nationalfleetparts.com/6_0l.asp Only refill with 13.5 quarts. If the dipstick reads anywhere between Min and Max. Don't add more. I find it easier to do my own so I can do it when I want and I know it is done right.
Old Sep 9, 2004 | 06:17 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
I am with Steve on this one, do it yourself, all my cars I take to get the oil changed, my truck I do myself...
Does not mean I do not like my cars...easy on the cars tuff for anone else to do my truck the way I would/do!
Old Sep 9, 2004 | 12:46 PM
lombardo96's Avatar
lombardo96
SBV 45, thank you for the info. I was wondering why you only but 13.5 quarts. Does it take more than that? thanks again.
Old Sep 9, 2004 | 12:54 PM
lombardo96's Avatar
lombardo96
Another question for you guys. How do this Wix filters compare to the factory filters? thanks
Old Sep 9, 2004 | 01:14 PM
IB Tim's Avatar
IB Tim
Try a search for WIX filters, in this the 6.0 forumm then try one for oil filters also...
Old Sep 9, 2004 | 02:18 PM
SBV45's Avatar
SBV45
There is a 15 quart capacity but about a quart and a half stay up in the high pressure reservoir, pump and rails. Too much oil seems to create foaming from windage from the crank. A big vortex if you will. Foaming will cause some erratic performance especially at idle. Some of the dip sticks are of varying lengths coupled with the dip stick tubes not being uniform seating can give some funny results. Fill up with 13.5 quarts. Run the engine for a few minutes and check for leaks, etc. Then wait 15-20 minutes and check your oil level. That is the level you should keep.
Old Sep 9, 2004 | 03:27 PM
AV3Fire's Avatar
AV3Fire
Got a good price on Rotella T at tractor supply comp. last nite......1 gal of 15w-30 for 5.98 per gal!!!!!!! bought 12 to stock up!!!!
Old Sep 9, 2004 | 03:28 PM
AV3Fire's Avatar
AV3Fire
Also got a quote from www.filter1.com
Filter Quote:
2004 F250 6.0L Diesel:
57314 oil $11.58
42731 air $38.34
33599 fuel $39.00
Old Sep 9, 2004 | 06:24 PM
utahtom's Avatar
utahtom
I change it myself with the Fumoto... One of the Utah dealers does the 6.0 for $51 including the oil & filter. Good deal for someone (else). They laughed when I told them they just wanted to get my truck up in the air to see what they could sell me via their 18 point maintenance check.
Old Sep 9, 2004 | 08:32 PM
Rick Braden
If you call filter1 they will tell you the 6.0 psd oil filter is not a wix. It is a Racor. If you buy an oil filter at dealer, carparts store, STP brand, or Filter1, they are all the same in the same shrink wrap & same xeroxed directions for install. Take care, Rick
Old Sep 10, 2004 | 11:04 AM
lombardo96's Avatar
lombardo96
for all you guys buying oil at walmart, what brand and what mixture are you buying?
