Cam Recomendation
Old Sep 8, 2004 | 05:06 PM
rschwab's Avatar
rschwab
Question Cam Recomendation
F100 short bed 2 barrel 302(bone stock) c-4 auto w/stage 2 shift kit has 2.73ish gears will be changed to 3.25 or 3.50, and has 275/60-15 tires. Will also be changing intake and adding a holley 600cfm vacuum secondary and long tube headers.
Will only be towing a couple jet ski's and very light camping type loads.
Old Sep 8, 2004 | 08:36 PM
ga302p's Avatar
ga302p
Get a matched kit. Edelbrock cam carb and intake. Or Holley Carb, weiand intake, lunati cam; some of the Holley kits have Holley intake instead of Weiand. The companies do all the guess work for you when they put the package together.
Old Sep 9, 2004 | 07:30 AM
jwtaylor's Avatar
jwtaylor
I would call comp cams and see which extreme energy cam they recommend for your application, they are newer grinds and provide a little more torque and manifold vacuum than most other cams at this time. The edelbrock cams if thats your thing, can be found through paw performance under their generic cams, same grind just $50 cheaper. later
DiegoMarla
Nov 17, 2008 03:01 PM
bryrykim
4 Cylinder Engines
13
Aug 19, 2007 01:36 PM
1984 f-250
4 Cylinder Engines
18
Nov 15, 2005 09:44 PM
warren1994
Nov 10, 2004 11:44 PM
new2dsl
Jun 20, 2004 12:06 AM
