How to remove vent window handle???
Old Sep 8, 2004 | 03:00 PM
Hbeckett's Avatar
Hbeckett
Anyone know how to remove the handle on vent window on 74f100?? Want to replace them but want to make sure I can get them off before purchasing.
Old Sep 8, 2004 | 03:03 PM
74crwcb429hibPS4spd's Avatar
74crwcb429hibPS4spd
I'd like to know as well thanks
Old Sep 8, 2004 | 03:37 PM
dfisher1's Avatar
dfisher1
All,
I thought they had a roll pin in them?
I'll check when I get home.
KingFisher
Old Sep 8, 2004 | 04:43 PM
460f250's Avatar
460f250
I think they do have a roll pin, but is there a way to tighten them other than wedging something between them and the wing window frame?
Anybody have ideas?
Old Sep 10, 2004 | 12:26 AM
Mil1ion's Avatar
Mil1ion
Once they are bent...no there isn't unless you remove the frame... then the glass.
Old Sep 10, 2004 | 02:32 AM
Torque1st's Avatar
Torque1st
Posting Legend
The roll pin rides in a groove on a stud. Usually they are loose because the window seal is gone. Remove the whole assy and repair as required. You can get parts at our sponsors. Make sure you lubricate the stud when you put it all back together. I like to use anti-seize on situations like this. To remove the roll pin you will need the frame out of the vehicle anyway. You will need a solid surface to hold the handle against to punch it out.
Old Sep 13, 2004 | 11:54 AM
Hbeckett's Avatar
Hbeckett
Thanks everyone for the help! I am going to order a couple. The plastic on the tip of the handle was worn out. i believe I will replace seals anyway while have everything off!
