'90 302 "Skip"
Old Sep 8, 2004 | 02:03 PM
jtmulreed's Avatar
jtmulreed
Question '90 302 "Skip"
Hello All,
I have a 90 302/AOD 4X4 that skips (or mis-fires) at low RPM under load. I've started to notice that it is doing it when idling also. Any ideas where too start?
Thanks!
Old Sep 8, 2004 | 02:12 PM
fordtradition's Avatar
fordtradition
I would start with a tune up. plugs, wires, and possibly distributor cap.
Old Sep 15, 2004 | 07:48 AM
bronco90's Avatar
bronco90
Unhappy
Hello, fellow broncs, I am new but I have the same prob with a 90 302 bronco. I have replaced plugs, wires, cap rotor button, distributer, EGR valve, map sensor,cracked manifolds,timming chain and gears,tested other sensors acording to hayes manual, also fuel filter. All made no difference.I have no codes in the obd, and talked to a ford mechanic, which he suggest take it to the service department.My bronco also has an intake backfire some times. The skip and backfire only happens at low speeds under a pull, otherwise the truck runs good.Also I set the timming, and changed the spout connector.Parts are mainly motorcraft.
Old Sep 15, 2004 | 07:57 AM
Steven@nd's Avatar
Steven@nd
Go read this thread about missing.
Sounds like you have the same trouble...
Old Sep 15, 2004 | 10:00 AM
bronco90's Avatar
bronco90
Smile 90 bronco skips and backfires
Thank You Steven@nd for the info. I talked to the ford mech. and he looked at my routing, thought it was o.k. He is leaning more toward injectors, but the problem doesn't do it all the time, and is real bad sometimes fuel mileage quite bad also. THANKS AGAIN
Old Sep 15, 2004 | 01:16 PM
jtmulreed's Avatar
jtmulreed
Thanks for follow up. I already have a copy of this TSB and this was the first thing I checked! I've tried cap & rotor. Plugs are next and then wires. Keep your fingers crossed!
jay3534
Sep 12, 2012 02:54 AM
Jbrown8988
Mar 6, 2011 05:06 PM
Jbrown8988
Feb 21, 2010 07:22 AM
beekermartin
1997 - 2003 F150
Nov 15, 2006 12:25 AM
